04-23-2015, 08:31 AM | #1 |
factory tach problem
My factory tach is connected to a 396 with an HEI ignition system but the tach reads on the low side. If you disconnect and reconnect the plug on the tach it appears to read normal for a few seconds and then goes on the low side again. Any thoughts?
1971 C-10 Short Bed |
04-23-2015, 09:25 AM | #2 |
Re: factory tach problem
Is the tach for a 6 cyl or v8? Should be stamped on the back side.
04-23-2015, 03:50 PM | #3 |
I had a similar issue and added a tach filter. But as stated above, make sure it's correct for V8 for I6
Thanks, Casey 71 Chevy C-10 SWB 350/400 PS, PB The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045 The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699 |
04-23-2015, 04:00 PM | #4 |
Or, clean out the tach filter. it may have R.P.M. dirt in it.. sorry, I couldn't help myself.
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
