Old 04-23-2015, 08:37 PM   #7
clinebarger
Re: 4l60e
Originally Posted by BR3W CITY View Post
There is a strength advantage in the 300mm's tho, right?
Yes, A longer Stator Support shaft, Helps keep the Input Drum stable.
Larger Converter Clutch. Hence the 300mm.
The Modular Case is the biggest strength advantage, However GM made 245mm, 298mm & 300mm versions using the Modular case.
It doesn't flex like the earlier "Cast-in" open bellhousing 4L60E/700R4 cases.
clinebarger is offline   Reply With Quote
