I'm trying....
![]() Join Date: Oct 2013
Which one is factory correct?
Which single exhaust routing is factory correct? Above or below the crossmember? Are they both correct? 2wd vs. 4wd...Thanks for your help guys...
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
Re: Which one is factory correct?
I am not sure but the one with it going above the cross member makes more sense to me.
1972 cheverolet K5 CST Blazer 350/auto/AC/PS/PB/Aux Batt From Medford, Oregon |
My 2wd 3/4 ton looks like the first picture
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
Not sure if you have noticed or not, but you have a picture of a 2wd and a 4x4. The 2wd is correct under the crossmember, and the 4x4 is correct above the crossmember since it hangs down lower.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#5 | |
I'm trying....
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 04-03-2015 at 11:32 PM. |
My 2wd has sections of what I believe is the original exhast, but mine is a 4-speed for now, so it doesn't have the transmission crossmember back there. But it does pass underneath the trailing arm crossmember, so I would think that it would have gone underneath an automatic crossmember as well.
#7 | ||
I'm trying....
Carpe manana
![]() ![]() Join Date: Dec 2010
Above the x-member for sure. Toss in a t-case skid plate while you are down there
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
![]() Join Date: Aug 2012
That's my 72 4x4 in the photo. It's original exhaust routing. The pipes original to the muffler. My father-in-law was the original purchaser of the vehicle when it was new.
I'm trying....
Thanks for chiming in...I just wanted to confirm before we went to the exhaust shop since yours is literally the only original 4WD Blazer exhaust pics I've been able to come up with.
![]() Join Date: May 2011
I know this is late and it appears you found you answer put thought I would had this for future questions
I'm trying....
Brilliant Dwayne...is that the Assembly Manual?...gosh, I'm embarrassed that it did not even occur to me to look there. The manual is such a PITA as you know. Ours is tagged and stickie noted and marked to death just so we've got a fighting chance of finding what we're looking for in under 10 minutes....and since the last time I picked it up was to look at the shroud mounting(and we're far enough along as to generally not need it), it's just been put to the side. Thanks for adding this to the thread. It definitely helps.
Got it from here
I'm trying....
That's awesome. Thanks. I guess I feel better that I didn't miss it in the AM...but it also makes me really want one of those.
#15 |
Really not a lot of pictures but picked it up on ebay for 45 plus shipping.
