Old 04-25-2015, 02:08 PM   #3
80SPORT
80SPORT's Avatar
Re: One ton dually to 1/2 conversion
We did one a long time ago ...
I think we used the 1/2 ton lower control arm and springs/spindles and the original 1 ton upper control arm with a 1/2 ton ball joint.
At the rear we took the spring hangars and everything off the 1/2 ton and installed on the one ton frame
I think we had to redo the rear shock upper mounts
Stretch the driveshaft and you are done .....
80SPORT is offline   Reply With Quote
