artillery wheels?
will a older set of 6 lug artillery wheels fit or trucks?... and if there are sets that fit anyone have on their truck what size tire worked best with them
Re: artillery wheels?
Senior Enthusiast
If using originals, be sure to carefully inspect them for any rust or damage. I believe these were last produced for the 1937-38 Chevy pickups, so they've normally seen a lot of hard use:
![]() They are probably skinny too, perhaps a 4.5" - 5" rim width. Modern aftermarket replacements can be had with a variety of wider rims with safety beads to retain the tire should it go flat.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
![]() Join Date: Oct 2009
i've got original artillery wheels on a truck and they require tubes because of the riveted spokes. mine are 15 x 5" and you can run bias-ply and some thinner radials with no problem.
Senior Enthusiast
I was just thinking back and remembering there was a guy around 1964 in Castro Valley that had a white 41 Chevy coupe running those wheels. They had been reversed and chromed, and were about the coolest thing I'd ever seen at the time. It was definitely unique.
Funny that this question/thread came up. I've been considering the same wheel for my 66.
If I'm reading correctly, (please confirm), no mods or spacers needed. The stock artillery wheel will mount flush against the 60's drums; the centers hub openings are same; and 6 lug bolt patterns are the same. Could be great news if I can find the wheels. If I'm not mistaken, our stock wheels are 5.5". As such, tire size shouldn't be an issue if artillery's are at 5". |
#7 | |
1961 crewcab
artillery wheels bring big money anymore, I has a friend sell a set for around 1200...
I have a pic of a 66 with a set that a board member had a few years back, I will try to find it... I do have a pic of this crew that not only has the wheels, but the o.g. gmc hubcaps mounted to them as well...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#9 | |
1961 crewcab
http://67-72chevytrucks.com/vboard/s...tillery+wheels
Moderator
![]() ![]() Join Date: Aug 2011
Wheel Vintiques makes them:
http://www.wheelvintiques.com/index..../limit/45.html The Wheel Smith makes a version: http://www.thewheelsmith.net/CustomW...cessories.html US Wheels sells them: http://www.uswheel.com/collections/h...readyartillery
![]() Join Date: Aug 2004
Jon,
That crew cab is the one I saw in a truck magazine about 12+ years ago that got me to start looking for a crew cab. I found one in my back yard ( 100 miles away) and bought it to build. I sold it to my dad and he built it, pix are above.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Ordered a set of 17x7s with 5x 4.5 and 5x 4 3/4 mulit pattern. Im waiting for the paint to dry on the bake cycle in the booth as I type this then off to the striper. I also have a wheelsmiths chrome set with painted hoops 15x8s on my burb. The og ones require tubes or silicone the rivets and they are really narrow.
GOD BLESS AMERICA! |
