Old 04-26-2015, 09:13 PM   #4
Mike C
Mike C's Avatar
Re: No-cut trailer wiring?
'69-'87 should be the same. Any autoparts store should be able to fix you up. A lot of the packages say '73 and up, but that's what I used on my '69.
You will have to add the circuit for the brakes. I did this on my '70 GMC using the no cut and then adding circuit breakers by the battery to a 10 ga wire run the length of the truck wiring as directed on the brake controller.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
