Old 04-25-2015, 12:55 PM   #176
mattbert56
mattbert56's Avatar
Re: 1965 C20 fleet side longbed DD low budget build.
Booyah!!! Rain last night and early morning. Huston we are a go. Clear blue sky's and 75 like that country song. Sunny and 75.
Well that didn't go as planned.
1965 k20 buikd thread: http://67-72chevytrucks.com/vboard/s...=628346&page=6
mattbert56 is offline   Reply With Quote
Old 04-25-2015, 01:05 PM   #177
mattbert56
mattbert56's Avatar
Originally Posted by akaupp View Post
Truck looks good.
Thank you man. Hopefully everything big will get buttoned up by end of next week. I have a whole 11 days off work! Holy never happens going to make em count.
Old 04-25-2015, 01:14 PM   #178
61K10
61K10's Avatar
Get er done Matt!
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 04-25-2015, 01:18 PM   #179
mattbert56
mattbert56's Avatar
Originally Posted by 61K10 View Post
Get er done Matt!
Yeaaaah buddy
Old 04-26-2015, 12:02 PM   #180
mattbert56
mattbert56's Avatar
She's back in and sitting Purdy. oh yeah! went in like a breeze. is all I can say. Put a high volume oil pump in it. The clearance was so darn close between the crank and pump I had to grind it a bit more for my own comfort. Also some pictures from the other day tho. Got a new clutch setup that I tossed in. Still more to come tho. Going to try and start the motor today.
Old 04-26-2015, 12:09 PM   #181
TJ's Chevy
TJ's Chevy's Avatar
Be careful with High volume pumps...they're known for breaking camshafts on these.
Old 04-26-2015, 03:17 PM   #182
mattbert56
mattbert56's Avatar
Darn it tj. Why ya have to say that. Ha. Is that regards to a high horse power motor
Old 04-26-2015, 03:31 PM   #183
TJ's Chevy
TJ's Chevy's Avatar
No, its how high you rev them...issue is that a high volume pump will pump some 50+ pounds when cold and up to 70 pounds at rpm which is to much and way more than needed. I went with a melling standard volume pump. At rpm I'll see 40 pounds which is plenty for a 6 banger. But you should be fine if you run a thinner 10-30 and don't rev it up to 6K. lol
Old 04-26-2015, 04:38 PM   #184
mattbert56
mattbert56's Avatar
I guess. Thing is I ordered a factory and the high volume pump. The high volume one is the same as factory size and everything. The normal one that was "stock" was 3 inches taller and looked like it was for a completely different motor. So I figured high volume won't hurt anything. Plus it doesn't get to cold in my area so this summer it should run fine. And if need be just find an original pump from maybe napa or auto zone and tull the pan to Toss that in. Won't take more than an hour. If that.
Old 04-26-2015, 06:21 PM   #185
68Gold/white
Look'n Good!!!
68Gold/white is offline   Reply With Quote
Old 04-26-2015, 07:56 PM   #186
TJ's Chevy
TJ's Chevy's Avatar
It'll be fine i think, and actually its the other way around(lol)...the high volume pump is bigger than the low volume which may even be the reason you had to do a bit a grinding. lol I know when I put my pump in I starred at the small bit of clearance between the pump and one of the crank balancers, I was like..."Uh huh, Nope...you getting a little metal shaved off", but then I just said heck with it and bolted it down and rotated the assembly by hand watching the clearance and all seemed fine...Guess we'll find out when that buzzin half dozen gets its 1st 6k rev. lol
Old 04-26-2015, 08:28 PM   #187
mattbert56
mattbert56's Avatar
That we will brother haha. Yeaa if I ever kick a rod on that cylinder that be a noisy day. I'm just going to run some thin oil for the break in period to play it safe and see what she runs up to. But if this just strips out my distributor gear on the cam then heck with it. I'll go buy a new bump stick. . Also. Wheat I Ment by the size of the pump. The "stock" oil pump was 3 inches taller and larger than the high volume. I think the box was miss labeled.
Old 04-27-2015, 02:23 AM   #188
mattbert56
mattbert56's Avatar
61 k10. Picked up that tig welder this weekend. Got her all set up and dialed in. Figured pictures of the fruits of my labor are in order behold the power of the little red welder from norway filled with parts from spain! Weirdest little machine.. enjoy The pics.
Old 04-27-2015, 02:27 AM   #189
mattbert56
mattbert56's Avatar
Also got a little more done on the truck but not much. Instal ed carb riser, carb, and air cleaner. Along with setting distributor in place. And the starters bolted in. Enjoy the crick in your neck from the second photo.
Old 04-27-2015, 01:21 PM   #190
61K10
61K10's Avatar
Hay Matt--Maybe i should of used it lol! Looks like it works well--enjoy.
1961 chevy K10
Old 04-27-2015, 01:27 PM   #191
mattbert56
mattbert56's Avatar
Thank you.
Old 04-27-2015, 01:41 PM   #192
1963c-10
1963c-10's Avatar
Looking sharp. Be nice to see that engine running.
1964 Short bed trailer
Old 04-27-2015, 01:46 PM   #193
mattbert56
mattbert56's Avatar
Oh she will purr soon. Taking the brakes today. I really really don't want to but figured all the more reason to have it done sooner. My goal is Friday now. There's a big car show at buns and burgers in town every year to kick off the summer car shows. Going to be 200 cars plus.
Old 04-27-2015, 09:15 PM   #194
mattbert56
mattbert56's Avatar
Okay so after pulling the hair out of my head 10 times I'm about 80 percent done with the brakes. I need a few springs and two adjusters for the front brakes and them I'm done. Other than bleeding the system. Also tackled my king pin bearings and races. Found the problem I think pit everything back in and she's as tight as 10 lb test fishin line with a 30 lb fish on Her. Should not have any problems with wheel camber. Tonight I'm going to tackle the transfer case. Have to change out idler shaft and the gears on it. Along with re sealing it all. Hoping to close shop by midnight. Just to wake up at 6 and start it all again
Old 04-27-2015, 10:27 PM   #195
TJ's Chevy
TJ's Chevy's Avatar
Also hoping to see that 6 banger purr. Have fun with the brakes. lol I can laugh cause I done mine!
Old 04-27-2015, 11:13 PM   #196
Joe Pass
Joe Pass's Avatar
Looking good....
Joe Pass is offline   Reply With Quote
Old 04-27-2015, 11:26 PM   #197
mattbert56
mattbert56's Avatar
Jee wiz thanks tj. Hah. Gunna get my gear on tonight buddy! Building that transfer case. Mmmmm gear oil
Old 04-27-2015, 11:28 PM   #198
mattbert56
mattbert56's Avatar
Originally Posted by Joe Pass View Post
Looking good....
Thanks amigo. Swing by anytime this week for a cold one on me if you would like. I have all this week off and I'm working on my truck from Sun up to till sun down. Plus good company is always welcome. Hope to see ya soon
Old 04-27-2015, 11:32 PM   #199
Joe Pass
Joe Pass's Avatar
thanks amigo. Swing by anytime this week for a cold one on me if you would like. I have all this week off and i'm working on my truck from sun up to till sun down. Plus good company is always welcome. Hope to see ya soon
ok,,,,,
Old 04-27-2015, 11:35 PM   #200
TJ's Chevy
TJ's Chevy's Avatar
Nice...I'll be expecting updates bright and early. Yeah...nice hot gear oil takes the place of coffee anytime. haha!
