Old 04-29-2015, 11:06 PM   #1
tjratt
Wire harness help
Hello everyone I am new to the sight and so far had been great. I am have trouble identifying a couple wires on my 72 C10 motor harness. The first one is a thick pink wire with female spade connector. The second is a black wire with a round boot.
tjratt is offline   Reply With Quote
Old 04-29-2015, 11:08 PM   #2
tjratt
Re: Wire harness help
Here is a photo of pink wire
Old 04-30-2015, 12:32 AM   #3
franken
I think the 1st is the blower motor.
I'm lost on the 2nd. You might try the electrical section where there are great color wiring diagram links. I actually took one to Kinkos and argued to get it printed and laminated for $11 on poster size paper. I rarely look at it, but its great.
That wire looks like it may have once been orange. The color fades.
Old 04-30-2015, 10:36 AM   #4
tjratt
I bet you are right on the blower motor. I have not hook power to it yet. I read somewhere else that the pink wire ran to the throttle stop on the carb when it had AC but could no verify.
Old 05-01-2015, 07:54 AM   #5
tjratt
I have an orange wire with a boot hooked to blower motor. Black wire boot is too big
Old 05-01-2015, 09:26 AM   #6
Custom/Ten
Custom/Ten's Avatar
Edit your signature to show us what your workin with like mine down below, is that a factory harness?
Custom/Ten is offline   Reply With Quote
Old 05-01-2015, 09:37 AM   #7
Custom/Ten
Custom/Ten's Avatar
I'm not sure what your working on but here's the pink wire on my truck, Name:  image.jpg
Old 05-01-2015, 02:37 PM   #8
tjratt
Is that hooked to the throttle sensor on the carb?
Old 05-01-2015, 04:47 PM   #9
70STOVEBOLT
70STOVEBOLT's Avatar
The pink wire runs to the idle control solenoid, which was part of the TCS system (transmission controlled spark) if I remember correctly. It does not have anything to do with A/C because my truck had it and there was no A/C on my truck, but that solenoid was there along with a relay mounted on the firewall, which was also part of the TCS. Don't know about the black wire with the boot.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 05-01-2015, 05:09 PM   #10
Custom/Ten
Custom/Ten's Avatar
It's an idle control solinoid but it doesent do anything, prolly cause I have removed my trans controlled spark. What was left of it anyway. I honestly had no idea it was part of the tcs. Glad I spoke up on here, now maybe I'll take that junk off and just add an idle adjuster screw. Hurray for wire removal! I like it clean under the hood. I don't think I have the black wire but I know orange is right for blower motor. Maybe it's for ac which I don't have, there is a wiring diagram sticky in the electrical FAQ.
Old 05-01-2015, 05:26 PM   #11
Custom/Ten
Custom/Ten's Avatar
Maybe it is this, also part of the TCS. I cut the wire off mine and now it's just a cap.Name:  image.jpg
Old 05-01-2015, 05:27 PM   #12
Custom/Ten
Custom/Ten's Avatar
Old 05-02-2015, 07:00 PM   #13
tjratt
Looks like it hooked to the tranny. I had mine rebuilt and they must have taken it off. That would explain why I. Can't find the hook up.
Old 05-04-2015, 07:43 AM   #14
70STOVEBOLT
You should have an idle screw already. The solenoid only worked with the TCS system. You can remove it and it will not affect anything.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
