Old 04-26-2015, 08:14 PM   #1
trifiveshawn
anyone else have one corner set down after drop
I lowered my 84 c10 today and now the left rear set noticeably lower, right front is higher. I used 3 inch drop spindles and a belltech flip kit. Any ideas??
trifiveshawn is offline   Reply With Quote
Old 04-26-2015, 09:45 PM   #2
jakespade
jakespade's Avatar
Re: anyone else have one corner set down after drop
Tweaked frame?
jakespade is offline   Reply With Quote
Old 04-26-2015, 09:54 PM   #3
trifiveshawn
No I've checked all that, did body paint and frame for years
Old 04-26-2015, 09:55 PM   #4
jakespade
jakespade's Avatar
Hmmm body panels are good? Tires all same size? Air pressure all the same in all 4 tires?
Old 04-26-2015, 10:01 PM   #5
mopar250
mopar250's Avatar
I have sort of the same issue. My passenger side rear sits a little lower than the rest of the truck. I have DJM spindles and cut springs in the front and a flip kit in the rear. I also replaced all of the suspension bushings as I did the front end work and have just put new leaf springs in the rear. The truck wasn't sitting like this before all of the work and I know history of the truck and its never been hit and also never been worked hard to tweak anything. Sometimes I think its just one of those things that happens.
Some things you may check is to make sure the tail of the spring is set in the bucket correctly on the front end. As for the rear, make sure your axle is pushed up against the pins on the springs. If all of this checks out, you can measure from the top of the axle to the frame on each side to make sure the distance is the same or close. Or, just throw a whole air system under it and adjust each corner to your liking!
mopar250 is offline   Reply With Quote
Old 04-26-2015, 10:28 PM   #6
school boy
school boy's Avatar
I have the same issue in the front passenger sitting higher
school boy is offline   Reply With Quote
Old 04-27-2015, 12:12 AM   #7
trixter99
I have no time for this
trixter99's Avatar
You might have a weak spring it wouldn't have been really noticeable in stock height but it will be now.
1986 Chevy short box ( PROJECT )
1994 Chevy Blazer lifted 6"
2009 Gmc 2500 HD
1999 Hugger orange Camaro SS
2007 BMW X5 Sport
trixter99 is offline   Reply With Quote
Old 04-27-2015, 07:12 AM   #8
Liberty
Liberty's Avatar
Aren't our trucks kinda known for leaning towards one side?
Liberty is offline   Reply With Quote
Old 04-27-2015, 07:59 AM   #9
77c10
77c10's Avatar
Squarebody lean.....
Mine's lower on the passenger side than the drivers side. One day I'll try to figure it out.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 04-27-2015, 09:15 PM   #10
trifiveshawn
I switched leaf springs from left to right after reading an older post.. No change. I'll pull coils one day this week to check them and cut down a little
Old 04-27-2015, 11:00 PM   #11
Big Dawgs 86
Big Dawgs 86's Avatar
I have the same problem.. The front sit even and the back sit 1in lower on the drivers side.. I'm thinking it's the shock placement on the truck. The one on the drivers side sits to the back while passenger shock sits to the front of the axle..
Working on my 2001 Chevy 1500 4x4...
Big Dawgs 86 is offline   Reply With Quote
Old 04-30-2015, 08:05 PM   #12
trifiveshawn
Ok if switched the rear springs from one side to the other, pulled the coils to cut 1/2 a coil out and they are same height. still sits horrible. Left front is 28" to molding, right rear is 28", left front is 30", left rear is 26". Any ideas of a fix? this thing is killing me lol
Old 05-01-2015, 07:51 AM   #13
77c10
77c10's Avatar
I'm changing my front springs so I decided to measure mine on all 4 corners before I started....
Old 05-01-2015, 08:28 AM   #14
Hammered 77
Hammered 77's Avatar
Tri5 have you measured four points to the bottom of the frame to rule out body mounts? Just a thought.
Rick
Hammered 77 is offline   Reply With Quote
Old 05-01-2015, 11:21 AM   #15
SCOTI
SCOTI's Avatar
Did you measure each corner before lowering? Chances are it might have had the issue before but wasn't noticed because the larger gaps make it less obvious.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-01-2015, 07:44 PM   #16
Super_Dave
Super_Dave's Avatar
Just put new KYB's on all four corners of my C20... was level with the worn out shocks... now the passenger front is at least an inch lower. I am hoping that after settling in, things will level out... time will tell.
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair
"Life is tough - wear a cup!"
"Old Enough to Know Better - Too Young to Resist"
"Junk is something you will need three weeks after you throw it away."
Super_Dave is offline   Reply With Quote
Old 05-01-2015, 07:45 PM   #17
trifiveshawn
Body mounts are good I checked that, frame is good. Yes scotti it was off some before as well
