05-01-2015, 12:41 PM | #1 |
early classic drop Spindles
Has anyone used these. I was thinking of just getting these since I have all of the GM brakes. They said they take all the stock parts.
Here is the description : Drop Spindles achieve their lowered stance by relocating the spindle pin higher in the casting, which in turn lowers the vehicle by an equal amount. The stock spring and shock absorber travel remain untouched, leaving the factory suspension geometry intact. Gone are the harsh ride and alignment problems common with other forms of lowering. Early Classic Drop Spindles are the original '60-'72 Drop Spindles, and are machined to accept your original tie rods and ball joints (Disc Brakes required). While others offer later model parts that require changing your suspension components in order for them to fit, every Early Classic Spindle is designed for your specific year and model of truck. Early Classic Drop Spindles are engineered to lower your Truck 2½", allowing the maximum amount of front wheel backspacing on the market.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
05-01-2015, 12:45 PM | #2 |
67-72 parts collector,…
Re: early classic drop Spindles
Thats a great choice.
They have been in business a long time.
05-01-2015, 12:47 PM | #3 |
05-01-2015, 12:48 PM | #4 |
what he said |
05-01-2015, 01:05 PM | #5 |
I know they have been around for a long time. Was just wondering if anyone used these. I bought a panhard bar from them back in 2002 ish and it is still in the box.
05-01-2015, 01:51 PM | #6 |
I've used them along with a ton of board members on here.
They are my first choice for 67-72 suspension parts. Great customer service.
05-01-2015, 01:52 PM | #7 |
Are you trying to sell the panhard bar?
05-01-2015, 02:40 PM | #8 |
Never Ending Projects
There is likely more ECE parts in use then anyone else out there. I bought parts from them back in '97 time frame. They don't have big flashy ads in the mags but been the leader for the '60-'72 trucks because of word of mouth.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
05-01-2015, 03:58 PM | #9 |
got them on my 63
05-01-2015, 04:03 PM | #10 |
No.. I plan on putting it on my truck someday maybe. I think back then it was like $69.
If I go this route I will definitely order from them. Thanks for the feedback.
05-02-2015, 04:25 PM | #11 |
Have them on my 66. Nice fit, high quality. Get them , you wont be disappointed
66' Short Stepper- 350-NP440/4speed Under Construction - http://67-72chevytrucks.com/vboard/s...d.php?t=629426 |
05-02-2015, 05:33 PM | #12 |
Early classis is where I orderd mine from, most everything on the chassis came from there, good quality parts all I need now is the sway bar
STEVES 63 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=412554 GIBSON63 YouTube channel https://www.youtube.com/user/1gibsonl4 |
