Old 05-02-2015, 11:49 AM   #1
vince1
Center support bearing removal
Pulled the front shaft with attached spline and bearing out from the rear shaft. Removed the D clamp and rubber. I am left with a bell on each side of the bearing. Tried tapping with a hammer and large screwdriver but nothing moves. Is there a trick to getting these bearings off? Thanks.
vince1 is offline   Reply With Quote
Old 05-02-2015, 12:23 PM   #2
DPowers
One foot in front of the other
DPowers's Avatar
Re: Center support bearing removal
I used a press.
DPowers is offline   Reply With Quote
Old 05-02-2015, 12:47 PM   #3
vince1
I guess I will try to rig up a puller. A press is on my wish list.
Old 05-02-2015, 01:03 PM   #4
vince1
I am trying to attach a picture. Maybe yes, maybe no.
Old 05-02-2015, 09:29 PM   #5
vince1
Looked on kijiji and bought what was advertised as a 20 ton press but it ended up being a 30 ton. Really didn't want it so big but price was right. Now I will have to get the truck going again so I don't have to dismantle the thing to move it.
So the replacement bearing they sold me is an SKF HB88107-A. It has a press on collar about 3/16" in height. I am thinking it probably goes on after the bearing but not really sure. Anybody ran across this before? Thanks.
Old 05-03-2015, 01:03 PM   #6
jayoldschool
Moderator
jayoldschool is offline   Reply With Quote
Old 05-03-2015, 01:04 PM   #7
jayoldschool
Moderator
I had to torch off the old bearing, it wouldn't pop in the press. Used the press for the new one.
Old 05-03-2015, 03:53 PM   #8
vince1
I was afraid to use a torch but it would have been a lot easier.
I laid the shaft on a piece of carpet on the grass. A few light sledge hammer whacks on a piece of 1 1/2" iron pipe sitting against the inner race of the bearing did the trick.
