Old 05-03-2015, 10:21 PM   #1
In The Ten Ring
Cab floor rust: what are my options?
This truck's previous owner, my dad, had it bondo'ed and painted back in 1990......they skipped over this hole!
I'm thinking about riveting in a patch and undercoating beneath, getting me by until I hire a (real) "body shop" to fix it right. It's in a bad spot though as it is "L" shaped.... and the rust area includes all of the surrounding brown-tinted metal.
I had planned on driving it as is, and getting this fixed later, when I have some cash saved up.
What do you guys think are my options?
In The Ten Ring is offline   Reply With Quote
Old 05-03-2015, 10:56 PM   #2
Willys47
Willys47's Avatar
Re: Cab floor rust: what are my options?
I would repair this area the rite way it looks like the seat belt area is affected and safetyfirst may be something to think of !
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 05-03-2015, 11:26 PM   #3
57taskforce
All about them K’s
57taskforce's Avatar
They make the patch for it... Just cut the old out, weld the new in, under coat the bottom, spray bomb the top, and Call it good. Sure I make A bunch of assumptions on that statement but it's always better to cut the rust out than rivet a patch over it. Fix it once and be done. The only thing I warn against is check the rear outer floor supports closely, if there's rust there Id be willing to bet that the supports are rusted too.
Tyler
Old 05-04-2015, 04:14 AM   #4
In The Ten Ring
I'm a noob but I got the truck for a much better price than most anyone here.
Can you hit me with a pic of these "rear outer floor supports?" I don't know what those are.
Old 05-04-2015, 07:24 AM   #5
hugger6933
you have to be under the truck to see the rear floor supports. It is the piece that goes past the cab mount and is going over to the inner rocker. It is kinda square looking piece and it looks like it is bolted to the truck.
hugger6933 is offline   Reply With Quote
Old 05-04-2015, 11:40 PM   #6
In The Ten Ring
Thanks. I'll try to get under there tomorrow for a look and even come back with pics.
If my cab is too rusty to make properly fixing it affordable, I am ready to "take the plunge" on getting a new cab.
Old 05-05-2015, 12:07 AM   #7
88Ironduke
If the possibility of taking the plunge for a new cab is there I would be extra stringent on my assessment of the current sheet metal. Cab corners around the rain gutters, door jams/seal area, inside the vent doors and various places underneath. Reality is that decent welding equipment cost decent money. Don't forget grinders, cut off wheels, etc. It isn't all about the gas mig welder and helmet. The devil is in the details. Factor in patch panel cost, time spent, and what it would cost juts to get started welding/grinding etc. This stuff ain't cheap added up. You may be investing in yourself for the long haul and hats off to ya. Your current cab with a good title is worth good $$$ to guys who already have the toys to weld in panels as required. Weigh your options carefully, welding/fixing a cab can be extremely time consuming but it is absolutely worth the effort and the reward of doing it yourself.
Just my .02 cents.
Paul
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!!
My Build Thread: Project 72' Green
http://67-72chevytrucks.com/vboard/s...d.php?t=587932
88Ironduke is offline   Reply With Quote
Old 05-05-2015, 12:46 AM   #8
In The Ten Ring
Well I am not as cool as you might think. I plan on getting estimates from local body shops/men and see how much proper repair of the bondo/rust will be. I would like to get a MIG and even stick welder later, but I'd have to get the truck running first so I can then clean up and organize my garage. It's just not big enough for much of anything else as things stand now.
But after I do clean it up and get it organized, I think I'll buy up some junkyard doors, etc. and learn how to weld.
Old 05-05-2015, 12:24 PM   #9
KEWLKATDADY
better to have brown tint on the metal than the dirty pair of underwear in the 1st picture...
1967 C10 custom
KEWLKATDADY is offline   Reply With Quote
Old 05-05-2015, 12:35 PM   #10
In The Ten Ring
YOU GUYS!
I use worn out clothes as rags and yes, those were washed one last time before being put into the "rag bucket."
