Old 05-02-2015, 10:18 PM   #1
PDXk5
PDXk5's Avatar
Bouncy Fuel Gauge
What is normal for our rigs? How much should the needle bounce?
I have a 1972 K5 and recently replaced the original cluster with a restored cluster. After taking the rig out for a test drive after replacing the cluster I noticed the gas gauge bounces a lot. I have to be honest, I don't drive the rig much since buying it so I don't remember what it was like with the original gas gauge.
How much bouncing needle is normal from sloshing gas in the tank? Mine will bounce and when coming to a stop at a red light, it will not stop bouncing before the light turns green again. This seems excessive to me.
Tbone1964 is helping me and we would like your input.
Thanks !
PDXk5 is offline   Reply With Quote
Old 05-02-2015, 11:44 PM   #2
87Skier
87Skier's Avatar
Re: Bouncy Fuel Gauge
I don't think it is really a question of how long it bounces but how much.
Mine will move a little bit, but not much. I think these trucks had slow moving gas gauges, you might just have one now that moves a lot faster.
Also, how much does it bounce? Around 1/4 of the gauge?
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 05-03-2015, 12:13 AM   #3
Chulisohombre
Chulisohombre's Avatar
Mine doesn't bounce much. The slider and float go Up And down slow so that doesn't happen. Or isn't supposed to happen.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 05-03-2015, 08:50 PM   #4
Senorx
Senorx's Avatar
My fuel gauge doesn't work at all. It's on my short list of things to get done this year.
Senorx is offline   Reply With Quote
Old 05-04-2015, 06:29 AM   #5
ls1nova71
ls1nova71's Avatar
I had a gas gauge do that once and it turned out to be something wrong with the gauge. I took it out and just by shaking the gauge the needle would move. The needle is supposed to have a little bit of resistance in it, but this one you could blow on and make the needle move. Changed it out and never had a problem again.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
