05-04-2015, 10:11 AM | #1 |
head light knob removal
Ok,,,,I'm taking the bezel with all the gauges in it out of the dash on a '69 chevy short bed,,,,how do you get the knob for the headlight switch off. Looks like the knob for the window wipers has already been replaced with one thats got a set screw in it. Might I have to do the same thing with the headlight knob? Thanks,,,Bill
05-04-2015, 10:20 AM | #2 |
Re: head light knob removal
1. Pull the knob all the way out (headlight on position).
2. Reach up to the switch behind the dash. 3. Locate the small button/plunger on top of switch. 4. Press button/plunger. 5. Pull the knob shaft out. Don't forget to put the shaft/knob back in to turn your lights off.
'72 Blazer, A/C, tach, tilt. Not on the road at this time '87 v30 Custom Deluxe, standard cab, SRW, Utility bed '86 c10 Silverado longbed (for now) '19 ecsb, 2500, 4x4 '15 Subaru Legacy - commuter |
05-04-2015, 11:13 AM | #3 |
Thanks for the info,,,,I"ll hunt for it,,,,LOL,,,redoing the dash,,,airbrushing it,,,,
05-04-2015, 12:04 PM | #4 |
The Older Generation
You will have better luck if you only pull the knob out to the park light position before you push the spring loaded button in.... Here is a picture of it. (not my pic) LockDoc
05-04-2015, 12:20 PM | #5 |
Learned something new today..... Never knew about the spring loaded button !
Who said you can't teach an old dog new tricks ???
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
05-04-2015, 03:38 PM | #6 |
Someone ought to chime in, since the wiper knob is probably also going to have to come off: There's a set screw on the wiper knob. Flathead, small screw that will let the knob for the wipers pull off.
05-04-2015, 04:45 PM | #7 |
Jeeeez,,,,thanks for all the replys,,,the pic helps too,,,,,
