Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-14-2015, 11:56 PM   #1
67ChevNut
Smile 1969 Engine Bay Wiring Problems
I am doing this TBI conversion and I am unable to connect the following wires on the pictures here. One picture shows two wires coming out of the firewall right above the engine wire harness plugs. The bigger wire starts at the ignition switch, but don't know where it goes, and the smaller yellow wire either. It appears somebody messed with them before and they were not properly connected. I am thinking one of them goes to the starter or battery. Like to know where they are supposed to start and where they are supposed to end. I looked at the wiring diagrams already and still having a problem identifying them.
The other pics. are connectors from a starter wire harness I bought from classic parts. I need to know where the black connector with the pink wire goes to, I believe the white connector goes to the HEI distributor. Can somebody help me? Appreciate all replies.
67ChevNut is offline   Reply With Quote
Old 04-15-2015, 12:05 AM   #2
67ChevNut
Re: 1969 Engine Bay Wiring Problems
Having problems loading pics, here is another try
Old 04-15-2015, 12:08 AM   #3
67ChevNut
One more try
Old 04-15-2015, 12:14 AM   #4
67ChevNut
Another pic
Old 04-15-2015, 12:17 AM   #5
67ChevNut
Don't understand why this thing only lets me load one pic at a time, this is the last pic.
Old 05-03-2015, 06:52 PM   #6
rocknss
rocknss's Avatar
I believe the green wire is for the temp sensor, mine looks just like it. As for the pink mine went up to the carb which I use for the electric choke.
I bought a new engine harness and all wires had the length to only go to there respective place in the engine bay.
Steven
69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners
2017 50th Anniversary Camaro SS
2004 Chevy Impala LS
2016 Chevy Malibu LT
rocknss is offline   Reply With Quote
Old 05-04-2015, 08:57 PM   #7
67ChevNut
[QUOTE=rocknss;7158168]I believe the green wire is for the temp sensor, mine looks just like it. As for the pink mine went up to the carb which I use for the electric choke.
Great, I am doing TBI so I won't need to conect the pink wire. Thanks for the reply.
alternator, firewall, harness, pink, wiring
