Old 05-07-2013, 09:23 AM   #1
concretekiller
ignition switch connector
Will the connector off of a 67-72 C10 fit the ignition plug for a 60-66? the connector looks the same, i just want to make sure before i buy one. I tried looking for a connector for my '65, but nothing was coming up.
concretekiller is offline   Reply With Quote
Old 05-07-2013, 11:47 AM   #2
tincan1966
tincan1966's Avatar
Re: ignition switch connector
try www.repairconnector.com.
I looked there and their listing is '67-'93 for dash mounted ignitio switches. Good picture of it, too, looks quite different.
If your housing is good, they have the correct replacement terminals, that work in the housing.
I'd double check with them, they have alot of hard to find pieces and the prices are reasonable.
tincan1966 is offline   Reply With Quote
Old 05-07-2013, 11:51 AM   #3
concretekiller
yea thats what im looking for. I already bought a new lock cylinder and am about to buy a new ignition switch, i just wanted to make sure the plug for 67 and up is the same as 60-66. It looks like it is.
Old 05-07-2013, 12:02 PM   #4
tincan1966
tincan1966's Avatar
Doesn't look to me like they'd interchange
Old 05-07-2013, 12:06 PM   #5
tincan1966
tincan1966's Avatar
Switch on left is a '64-66.
switch on right is a '67-72
Old 05-07-2013, 01:04 PM   #6
concretekiller
Ah, ok i see now :-(
Old 05-07-2013, 01:05 PM   #7
concretekiller
I see what your saying about my plug being in good condition, just replacing the termnials and wires. I may have to go that route.
Old 05-07-2013, 11:14 PM   #8
argonaut
argonaut's Avatar
I don't know of anyone that reproduces that plug. So i always save old wiring harnesses that i find si that i can have the right connectors when i need them. However I recently discovered that the early 60s impala switches have the same pinout. Perhaps there is an ignition switch connector marketed for the impalas? Just a thought.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 05-03-2015, 12:31 PM   #9
thefaceman
thefaceman's Avatar
Did you ever find the right pigtail? I'm trying to find one for my 66. What if I just switched out the ignition switch for a 67 and bought that pigtail?
thefaceman is offline   Reply With Quote
Old 05-04-2015, 12:29 AM   #10
Captainfab
60-66 Nut
You might want to verify that a '67 ignition switch will fit the '64-'66 dash hole. If you have the correct plug for your '66 ignition switch all you need is the Packard 56 style wire connectors. Those can be found at NAPA but they are stupid expensive there last time I had to buy some. Here is one of several listings on ebay.
http://www.ebay.com/itm/25-Packard-5...6a8df2&vxp=mtr
Old 05-04-2015, 01:41 AM   #11
jtrichard
I just bought some packard 56s (female) at $1.00 EACH OUCH
jtrichard is offline   Reply With Quote
Old 05-04-2015, 11:42 PM   #12
Captainfab
60-66 Nut
The last time I bought some at a local NAPA they were over $2.00 each.....might I emphasize the last time
