![]() Join Date: Feb 2014
Questions for the 1 ton/Dually owners
Been looking for threads to read on the 1 ton /dually trucks for the 1960-1966, found a few... is it as easy to upgrade the C30 as it seems to be on the C10?
If you know of any good threads on doing upgrades to brake, steering suspension on our series trucks, please share some links. Doing some research before pulling the trigger on one...YES, that is a first for me! Thanks, Pappyx4! |
Re: Questions for the 1 ton/Dually owners
I'm a big fan of 1-Ton trucks. Have had 5 different ones through the years from '64 to '72. I still have 4 of them, but I won't be able to help much as I like them stock. Although I can answer your question though. It is not even near as easy to upgrade them in comparison to the C-10.
Keep us posted when you buy one though. Bill
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan |
60-66 Nut
As far as front disc brakes, power steering and power brakes, yes it is just as easy as it is on a C10 or C20. You will just need parts for a '71-'86 C30 or '87-'91 R3500. Most of the '60-'66 C30's will have the Eaton HO52/72 which typically are low geared. I would recommend switching that differential for either a Dana 70 or a 10.5" 14 bolt, which will have a more highway friendly gear ratio.
My '66 C30 project has a late 70's front suspension and a Dana 70 from a '78 F350. I just had to move the spring pads inward a little.
Thanks for the replies guys. I'm thinking that I want the truck to maintain the stock look but would like to upgrade the brakes steering and suspension probably use it most for pulling trailer... To bring other projects home
Captan fab do you have a build thread on your c30 project? |
60-66 Nut
No I do not have any build threads here....no time to work on any of my trucks, let alone keep up with a build thread.
#6 | |
[QUOTE=Pappyx3!;7139326]Thanks for the replies guys. I'm thinking that I want the truck to maintain the stock look but would like to upgrade the brakes steering and suspension probably use it most for pulling trailer...
To bring other projects home I have 64' C30 I am upgrading with parts from a donor 80' C30 using drivetrain and suspensions to bring a freeway friendly rear end, disk brakes, and a Hydroboost power brake system to the mix. Finding a donor truck (73'-87') is the way to go since it is cheaper than the kits and Chevy parts are readily available. Although the original I230 purred like a kitten, I opted for the 350 sbc engine. Within the cab upgrades are as easy as they are with the C10's but the rest..."forget-a-bout-it" unless you can spare an arm or a leg. Check mine out...the last picture is really what I would like my dually to be but, alas...I'll hafta stop here for now as just this upgrade costs plenty. ![]()
Projects: 65' Chevy C10 swb (rebuilt chassis) 65' Chevy Panel swb 64' Chevy C30 flatbed "above" 80' C30 "beneath") Parts: 66' GMC 2503 & 65' GMC I1500 |
Thanks for all the comments and info.
OldGMJon, We must have had the same dream... that looks like an awesome truck you found to get started with. Please keep us posted on the build. Pappyx4!
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400 1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver John 3:16 |
#9 | |
EDIT: I apologize. I asked this same question last year in a different thread and it was kindly answered by Captainfab. The answer is use a master from a 67-70 C30. Thanks...ned.
'63 C10 long wide; '61 Corvair Lakewood; '74 BMW 2002tii; '89 BMW 325i, '49 Ford 8N Last edited by ncoonen; 05-06-2015 at 04:26 PM. Reason: question was answered last year! |
#10 | |
Thanks...ned.
'63 C10 long wide; '61 Corvair Lakewood; '74 BMW 2002tii; '89 BMW 325i, '49 Ford 8N |
60-66 Nut
The Dana 70's are quite common in Fords and Dodge's. Although some Chevy dually's came with Dana 70's as well. The only conversion I have done is on my '66 C30 with which I used a Dana 70 from a '78 F350. I have to move the spring perches inward a little to line up with the '66 springs. That differential has 4.10 gears, which aren't really highway friendly unless you go with an OD trans which I will be doing in mine. It has been my experience that some Dodge vans came will taller gears than a typical 1 ton truck. However the van housings are a bit wider than a typical pickup differential. If you are going with a flatbed that wouldn't really be an issue. If you don't need the higher weight capacity of the Dana 70, a Dana 60 would work equally as well. Those are again easily found under Fords and Dodge's.
Chevy addict
My brother has a 1988 1 ton Chevy that came with 3:42 gears, not sure what model rear it is though.
