Wheels
I picked up a set of old school aluminum slots off EBAY. They have the large center holes and the appropriate lug spacing, no problem one would think and that is true with the back wheels, but not the front. The drums have a little pin sticking through the front in 3 spots. The flange on the back of the wheels is of course flat. The old steel wheels seem to have a recess to accommodate the pin sticking through. I'm calling it a pin but really don't know what it is or it's purpose. Wondering if I can just grind it down to allow the flange to seat flat against the drum which is what is needed. Tell me what you think and thanks. The white arrow shows one of the pins. Surely some of you have ran into this.
Never Ending Projects
Re: Wheels
My guess it it was part of the original factory rivet to hold the drums on during assembly. Someone likely cut the head off, so they could get the drums off to change the brake shoes. You can grind that down or pull the drum off and knock out the rest of the rivet.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
![]() Join Date: Mar 2014
Re: Wheels
It's a locator pin and can be removed.. some cars have that style pin and some have a bolt, but either way they can be removed. And yes the original steel wheels have provisions to clear it.
Re: Wheels
They are rivets/pins. the hub and drum on these are riveted/pined from factory on the fronts. I ground mine off and made it where i could remove the drum without having to take hub off. won't hurt a thing.
Nice wheels by the way!!
1964 ![]() |
Re: Wheels
Yes grind them.
GOD BLESS AMERICA! |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: Wheels
Grind them, and then show us your truck with those slots. :-)
Re: Wheels
SLOTS!!
![]() Love some slots. I don't know about you bud ..but I was one happy M*fo when I picked up my set
66' Short Stepper- 350-NP440/4speed Under Construction - http://67-72chevytrucks.com/vboard/s...d.php?t=629426 |
#8 | |
Re: Wheels
Your slots look nice. Of course, I'll admit that I am partial to slots. That's what I have too. Jeep Wagoneer slots from the 1970's. So happy I found them.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
Re: Wheels
yea I remember reading here that you can ditch the rivots. I personally didn't have the issue with mine. The set I found came of a 70 c10. Don't believe mine to be wagoneers
SORRY not trying to hijack the thread I just love slots. lol
Re: Wheels
Slots I did up for the 65. Polished outer, anthricite center including cap with the clear flattened, chrome 3 bar.
Re: Wheels
I hadn't found my slots yet
Re: Wheels
Jeff check your pm
Re: Wheels
pm back at you
Re: Wheels
Mine had slots on it when I bought it
#15 |
Re: Wheels
went ahead and ground them flat, good to go and thanks for all the comments and help.
#16 | |
![]() Quote:
Sam |
#17 |
Re: Wheels
The rivet can be removed by knocking it out with a punch. Not really necessary unless it is loose in the hole. It WILL be necessary to knock it out to remove the hub from the front drum. I did that when I had my drums turned.
#18 |
Re: Wheels
Success!! The first step in moving my truck from a rat to the next step up. Just ground down the rivets and no problem.
#19 |
Re: Wheels
Very nice!
#20 |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: Wheels
Man, do those ever make a change to your truck. Looks so much better. Totally suits the finishes.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
#21 |
Re: Wheels
Looks great!
