Junior Member
4 core brass/copper radiator direct replacement
I had to replace the 4 core radiator in my burb last week. The shop said they couldn't not repair my old one. I found that Orielly's has a direct replacement brass/copper radiator instead of the new plastic models. It was only $185 bucks and is part #433369. It does not have the outlet for the heater hose and is set up with a cooler for an automatic transmisson.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: 4 core brass/copper radiator direct replacement
Good info, Thanks!
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
Have you installed it yet? Any fitment issues?
1970 C10 Short Stepper with 71/72 front clip. |
Junior Member
There were no problems with the install or fitment. My custom fan shroud fit perfect after drilling two new holes. I could not find a definative part number when searching threads prior to my purchase so I thought I would share.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 08-25-2014 at 05:15 PM. Reason: spelling |
![]() Join Date: Mar 2003
Good info, I just pulled mine out this morning and took it to the rad shop, we'll see whether or not they can fix a 45 y.o. radiator and call it good for a while
I have the same radiator in my truck. Figment was fine.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
Where did you get that fan shroud from. It looks nice like it was made for it.
Junior Member
It was custom made.
Old member
Here is my fan setup and it looks just like the ones pictured.
![]() http://www.hawksthirdgenparts.com/pr...2C100-CFM.html ![]() Here is mine.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I went to order this today and it is not on O'reillys website anymore....
Looks like this may have been the last of the copper radiators. BBB ![]() |
Junior Member
I don't see it either.
I had my original rad rebuilt with a copper/brass core.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
I bought 1 when we did the a/c install from Oreilly and works great and no problems with fitment
Thanks for the info... saving this for a rainy day
71 swb 350/4sp manual 5/7 static drop |
#15 |
