Closed Thread
Old 05-09-2015, 04:21 PM   #951
pimpston65
pimpston65's Avatar
Re: What did you do to your truck today part III
Bodywork ugg!!! These pieces are from my 65. I plan to finish ALL the bodywork, priming, wet sanding, then it's matte black time. Next week cab meets frame!!!
pimpston65 is offline
Old 05-09-2015, 04:32 PM   #952
_mg
Active Member
_mg's Avatar
Finally got the steering arm loose, good weekend so far! Replacing studs next.
_mg is offline
Old 05-09-2015, 06:23 PM   #953
TJ's Chevy
TJ's Chevy's Avatar
Originally Posted by 61K10 View Post
Looks nice TJ--Question--with the shifter that far back, what seat are going to use? Can you move the shifter forward? cool anyway.
According to one of the guys at Proformance powertrain you can use it all the way back there as long as a 3 inch forward shift lever is used. But yes, I can move it to the center if need be....its only another $400 for the stinkin shifter.
TJ's Chevy is offline
Old 05-09-2015, 06:33 PM   #954
pimpston65
pimpston65's Avatar
just a 1/64 scale model, got all the pieces hanging beggin to be painted!!!
Old 05-09-2015, 06:35 PM   #955
pimpston65
pimpston65's Avatar
check out my $20 hood rotissorie jig...
Old 05-09-2015, 09:14 PM   #956
Hugh in NC
Hugh in NC's Avatar
Washed the '63 Thursday evening. Friday, waxed and generally cleaned up real good for the Buggy Festival in Carthage, NC on Saturday, May 9. I thought my truck looked good until I saw some of the other trucks parked around me.
Hugh
Hugh in NC is offline
Old 05-09-2015, 10:44 PM   #957
Lugnutz65
Lugnutz65's Avatar
Hugh
Hugh,
That's one VERY SWEET lookin' truck you have and it can stand proud in any show. Hold your head high and be proud 'cause it's a great looking truck. Thanks for sharing.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 05-10-2015, 12:38 AM   #958
Jeff La
Looks dang good to me
Jeff La is offline
Old 05-10-2015, 10:19 AM   #959
Pappyx3!
Pappyx3!'s Avatar
Hugh
Other trucks you took pics of look nice and no disrespect to their owners but I wouldn't take all 3 of them for that 63 of yours.... That's a sweet ride!
Pappyx3! is offline
Old 05-10-2015, 10:24 AM   #960
Pappyx3!
Pappyx3!'s Avatar
I spent the day yesterday putting the engine and transmission back in the 62. Looks like I might have to modify the trans crossmember. Try to get some pics this afternoon.
Pappyx3! is offline
Old 05-10-2015, 11:27 AM   #961
LVPhotos
LVPhotos's Avatar
Hey Pappy, I cut my original manual crossmember out. The old adage "when in doubt, weld alot" was used on my frame. 2 Sawzall blades and couple cut disks.
Been working out of town so making the list and trimmed fenders for ground attack.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline
Old 05-10-2015, 01:23 PM   #962
Pappyx3!
Pappyx3!'s Avatar
Man you slammed that one... Looks great! Got a build thread I'd like to see it if possible.
Someone has already taken the MT crossmember out when they put the v8 in. I changed the front crossmember, motor mounts to to an 81 for the disc brakes... Looks like the engine and trans are moved back about an inch or so. I have a cpp tubular crossmember that I'm thinking of using, but will have to see how it fits up.
Pappyx3! is offline
Old 05-12-2015, 08:16 AM   #963
Pappyx3!
Pappyx3!'s Avatar
Here's a few pics of the engine/trans back in the 62, and first time it's been back on the floor with all the changes that have been made.
Pappyx4!
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400
1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver
John 3:16
Pappyx3! is offline
Old 05-12-2015, 12:21 PM   #964
lowslow64
lowslow64's Avatar
Experimenting with Buick hinges
lowslow64 is offline
Old 05-12-2015, 03:03 PM   #965
DLW
Got a break and finished fit checking the mild porterbuilt crossmember, DT headers, the LS3 and the CPP drop spindles and Baer brakes. Need to figure out the steering linkage and some bump stops next, pull it all back out and send for powder coating.
DLW is offline
Old 05-12-2015, 10:02 PM   #966
TJ's Chevy
TJ's Chevy's Avatar
More stuff!
Old 05-12-2015, 11:05 PM   #967
pimpston65
pimpston65's Avatar
Originally Posted by TJ's Chevy View Post
More stuff!
hey i have the same systems, hot rod matte black is mine. what color did you choose?
Old 05-12-2015, 11:46 PM   #968
TJ's Chevy
TJ's Chevy's Avatar
Boulevard black.
Old 05-13-2015, 03:26 PM   #969
pimpston65
pimpston65's Avatar
Boulevard black.
nice!!! i should be spraying by months end... also i got my 2 NOS front rubber brake parts in today!!!
Old 05-13-2015, 09:57 PM   #970
wilbur46
wilbur46's Avatar
Finally!!
A ground wire to the body does wonders for my lights (Duh)
I need to rebop a stock steering column, which is a mix of stuff, into a 66 column.
Anyone have a pic of the entire assembly or a link to one?
The components I've got won't go together.
Thanks, W
wilbur46 is offline
Old 05-13-2015, 11:36 PM   #971
TJ's Chevy
TJ's Chevy's Avatar
Pulled the bed off...getting ready to start the frame off.
Old 05-14-2015, 04:26 PM   #972
TJ's Chevy
TJ's Chevy's Avatar
Tore more of it down today. Slowly but surely. Pictures later.
Old 05-14-2015, 05:45 PM   #973
OldChevy61
OldChevy61's Avatar
Got the radiator out, heater hoses out, will get the rest of the front off the weekend and motor ready to come out. Also crawled around under a truck in the junkyard and got me a T5 for the build back.
OldChevy61 is offline
Old 05-14-2015, 08:04 PM   #974
pimpston65
pimpston65's Avatar
what kind of truck did the T5 come out of?
Old 05-14-2015, 08:12 PM   #975
OldChevy61
OldChevy61's Avatar
93,v6 S10.
Closed Thread
