![]() Join Date: May 2005
250 to 292 engine swap
The 292 I am going to put in my 66 was a 4 speed and I am going to mount it to a Powerglide. does the flex plate mount the same way? It looks different on 292 and the bolts need to be bigger. Has anyone done this before and have any advice? thanks
![]() Join Date: Aug 2013
Re: 250 to 292 engine swap
292's have the same mounting points for the bellhousing as V8's
On some 292's the flywheel/flex plate bolts are 1/2" instead of 7/16".
http://67-72chevytrucks.com/vboard/s...d.php?t=637533 |
Thanks for the help, guys. The bolts for the crank are bigger they are 1/2 in / 20 treads bought new and they fit nicely. Will re-drill flex plate to except new bolts. The bolt heads are thicker but should not be an issue.
you also require a different passenger side eng perch. that is the only one that is different from the rest in case you are not aware
ron |
