04-13-2015, 04:30 PM | #101 |
Sofa King Crazy!!
Re: Buried to Bagged 1972 2wd
Another weekend and got a little done!! I completed the front of the windsheild drip rail and it's ready for body work, the back is a different story. Found a few spots that will need some attention due to rust but overall I am still happy with the condition of this old Blazer. My brilliant idea Friday to build a body dolly went full circle and actually made it happen!! Came out pretty good, may be a little high so some tweeks will need to be made. I was really concerned about the front being so heavy that it might bend the body but after taking precautions it didn't budge!
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
04-13-2015, 11:15 PM | #102 |
My Spoon Is Too Big
I'm getting myself ready to do the 1999 5.3L LM7 swap any secrets you learned on the 1st truck.. send em my way. So far I have the 5.3 4l60 complete pull out with full computer and harness uncut.
seeing your 2wd blazer makes me hesitate to take the first step in my motor swap thinking what if I find a blazer to drop this into instead! . Then I look online see the high price per pound of rust that carries a blazer nameplate or that weird dual drives shaft thing I believe they call 4x4, I just sign off the computer and cry. Are you still at that same shop I visited? Maybe I could stop by again one dsy and learn some more.
1972 C20, 03-14-10 Build Thread 2000 Silverado 4.8L, 11-04-13 (Currently Parting) 1999 Silverado 5.3L, 07-07-14. (Engine Donor) 2015 Ram 05-20-15 (Daily Driver) |
04-14-2015, 01:37 PM | #103 | |
Sofa King Crazy!!
04-15-2015, 08:00 AM | #104 |
Still Learning
Your blazer tub looks extremely clean! I'm digging the new dolly too. Looking forward to where you go next with this build.
04-15-2015, 12:01 PM | #105 |
Sofa King Crazy!!
I was pretty happy with the tub too. I suppose 2wd Blazers did better over the years than most 4X4s. Sure am glad you jumped on board with the build!!
04-21-2015, 12:06 PM | #106 |
We need peekchures of these boxes from Porterbuilt stat!
04-22-2015, 09:56 AM | #107 |
Sofa King Crazy!!
I'll take peekchures of them for you tonight per your request. I went through them last night and everything is there from what I can tell. Quality stuff for sure! Welds look great, packaging is decent and I got a couple of elusive PB stickers!!
04-27-2015, 05:52 PM | #108 |
Sofa King Crazy!!
Alrighty folks, more peekshures as requested.
The bed was FULL of Porterbuilt and Accuair!! Actually made the old Dodge sqwat a little. First shot of the new and improved DM, well the newest one PB makes at least. I have no idea how to get this through the frame to bolt to the bottom of the frame...... Center PB Extreme crossmember with tons of adjustment and incredible welds. The shipping took it's toll on the center, a corner was bent, not bad but still bent. Thanks FedUp. And the little bitty c-notch!! For you Blazer guys the bumpstop rear rivet hole is where the back of the notch should line up so the body mount in the front will need to go bye-bye!!!!
04-27-2015, 06:02 PM | #109 |
Sofa King Crazy!!
While I was still drooling on my new parts the frame was begging to be torn apart so I could get these Porterbuilt parts fitted. The frame was not cooperative to say the least. I have a whole new respect for you Blazer guys. The gas tank had to be pulled, rivets had to be man-handled, and plugs had to be cut to fill in some holes so I can clean the frame up. What I didn't show is a clean frame with a little primer on it. Hopefully this is enough peekshures to keep everyone happy for a few days!!!
04-27-2015, 06:09 PM | #110 |
Sofa King Crazy!!
Almost forgot. I would like to thank Nate at Porterbuilt for getting back to me really quick on a couple of questions. Quality parts and quality customer support.
04-27-2015, 06:23 PM | #111 |
Awesome! Thanks for the sneak peak of the parts lol. I'm gonna have to stop by the shop again just so I can pet those shiny parts (and not the one on top of your head!)
Posted via Mobile Device |
04-27-2015, 06:37 PM | #112 | |
Sofa King Crazy!!
05-04-2015, 11:49 AM | #113 |
Sofa King Crazy!!
WooHoooo!!! Another weekend to spend with my new project. It's always nice having new parts to put on. Got the rear notches in, the front cross member installed and all the holes drilled for the trailing arm cross member. Sounds like a little to accomplish in a weekend but trust me, it is a lot!!
05-04-2015, 11:52 AM | #114 |
Sofa King Crazy!!
This Porterbuilt stuff is awesome. Holes line up, threads are clean, welds look great, fitment is spot on.........I can't say enough about this product. You absolutely get what you pay for.
05-04-2015, 11:55 AM | #115 |
Sick!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
05-04-2015, 12:10 PM | #116 |
A day late and $1 short...
Trailing arms on an extreme drop? Delmo tried this and decided to go with a 4-link on Mason Wrights "Larry", has PBFab made any changes since then?
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
05-04-2015, 12:26 PM | #117 |
67-72 parts collector,…
Gonna be a sweet chassis!
05-04-2015, 12:28 PM | #118 | |
I thought they had straight rear frame rails as opposed to the factory 2wd blazer's coil spring rear frame rails, that kick out like the coil spring trucks.
05-04-2015, 12:30 PM | #119 |
You may be correct Keith, using trailing arms will be much more simple with no 4-link brackets to weld on the axle tubes.
05-04-2015, 01:22 PM | #120 |
Sofa King Crazy!!
After talking with Nate via e-mail he mentioned nothing about a different setup for the Blazer, and as of now it looks like everything will work. I guess everyone will have to "stay tuned" in for next weeks updates to see the outcome of the "The Trailing Arm Saga". If you are looking for a easy way to get your PBFab parts, and in a package deal, look no further than Travis at Pro Performance. He has been instrumental in getting me what I need and in a descent time frame according to other distributers from what I hear.
05-11-2015, 01:25 PM | #121 |
Sofa King Crazy!!
Not much got accomplished this weekend, a wedding and mothers day kinda ate the whole weekend up. Although I did get the LCAs and UCAs on! I got heim-joints with everything I ordered but there was a problem with the left hand threads not working with the right hand threads on trailing arms. The ID on the heims were kinda not right either. The bigger ID heims should be right hand thread for the trailing arms and smaller ID heims should be for the tie rods. Well that's not confusing at all!!!
05-11-2015, 01:40 PM | #122 |
Looking good David.
05-13-2015, 01:16 PM | #123 |
Yes! Looking good!
Josh 1970 Chevy C10 SWB build thread http://67-72chevytrucks.com/vboard/s...d.php?t=639787 1976 Chevy k10 Silverado Bought new in '75 by my Grandfather 1965 Lincoln Continental Convertible - SOLD 1965 Lincoln Continental Sedan - SOLD |
05-13-2015, 01:40 PM | #124 |
Sofa King Crazy!!
Thanks Guys!! I think I have my UCAs upside down, guess that's why we do mock up.......
05-13-2015, 01:44 PM | #125 |
Sofa King Crazy!!
Got off the phone with Travis at Pro Performance, seems I was missing a couple of things. My Porterbuilt panhard bar was left out of my order and my lower shock mount crossmember for the rear was left out plus 2 other heim joints. Looks like I will be waiting again........
