Closed Thread
Old 05-11-2015, 10:11 PM   #2151
kingstrider
kingstrider's Avatar
Re: What did you do to your truck today? Chapter II
I bought this tach cluster before I even owned my truck. The air pressure gauge was from a big truck but I figured it would be cool if I ever wanted to bag the suspension and get it to work.
As luck would have it, I wound up buying this 72 Cheyenne Super that someone had added aftermarket gauges to:
Finally got around to installing the cluster in my truck, love having the factory tach. Still waiting on a new woodgrain appliqué to match the rest of the interior.
Here's the old cluster. I'm going to mount the water temp and oil pressure gauges under the dash.
kingstrider is offline
Old 05-11-2015, 10:39 PM   #2152
66pnl
66pnl's Avatar
Got my Hella e-code lenses and 3800lm led's in.
66pnl is offline
Old 05-11-2015, 10:41 PM   #2153
In The Ten Ring
Originally Posted by Ol 67 C10 View Post
may be a while before I get my truck going... but hopefully I'll have the 62 Impala done by the end of the summer. If not I'd still be happy just to get together sometime.
There is always time to have a beer or sandwich with a friend.
In The Ten Ring is offline
Old 05-12-2015, 08:07 AM   #2154
spidermn
spidermn's Avatar
That sounds like some plans are happening for the boys in the VA area. I'm in.
Go BIG or GO home!!
1970 Custom Chevy C10 / 350 bored .30 over / 5.5/7 drop on 20" boss 338
spidermn is offline
Old 05-13-2015, 12:54 PM   #2155
hamjet
hamjet's Avatar
Took out the 3OTT and installed a 2004r in the green 69. A little tinkering with the TV cable and she shifts nice. Next big project will be an engine transplant...
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline
Old 05-13-2015, 02:31 PM   #2156
Saclandman
Saclandman's Avatar
Picked up my new registration and plates and the DMV.
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline
Old 05-13-2015, 03:27 PM   #2157
chevy2tom
chevy2tom's Avatar
Hamjet, you're going to love that 2004r. I put one in my 71 behind a 454 with a 355 rear gear. 2k rpm @ 80 mph is awesome on the highway. Makes me want to branch out to neighboring states for swapmeets & shows.
chevy2tom is offline
Old 05-13-2015, 06:06 PM   #2158
hamjet
hamjet's Avatar
you're right about cruizing speed, its nice seeing the RPMs a lot lower..
Thanks, Joe..
hamjet is offline
Old 05-14-2015, 11:17 AM   #2159
matthamby
New to the forum! Will have lots of questions! I have my Grandpa's 1970 C-10 that he bought new, so I'm the second owner!
Last Saturday I got some used tires put on some rims I got off craig's list for $150 - I had to replace 2 rims that were so rusted they wouldn't hold air for more than a few minutes. It took me forever to find some rims that would fit that wouldn't break the bank!
I was hoping that the tires that were on the rims were good enough to use to roll around to start working on the old girl, but no dice! I'm hoping to have her on the road in the next couple of weeks. I will start a thread to show progress and ask questions!
matthamby is offline
Old 05-14-2015, 10:20 PM   #2160
In The Ten Ring
Fuel lines adjusted, flared, and installed! I have the in-cab connected to the frame line but stopped as it was getting late. I'll install the fuel shutoff valve tomorrow.
*And get pics.
Old 05-14-2015, 11:08 PM   #2161
Saclandman
Saclandman's Avatar
Bolted up my seat, installed my new 3-point seat belts, got my bed bolted down to the frame, installed my new core support, installed my new inner fender on the pass. side, got all the gauges and lights working correctly, and hung my new plates.
Unfortunately, all that was done in my head without even touching the truck. Darn job and responsibilities.
Rich J.
Old 05-15-2015, 12:06 AM   #2162
Ol 67 C10
Ol 67 C10's Avatar
Well I pushed mine outside and finally got my cab off the frame to get started on the rust repair. Will take some more pics tomorrow.
67 Chevy Shortbed Fleetside C10
400 SBC/Turbo 350/Posi
62 Impala SS (Clone)
350 SBC/4 Speed/3:36 Posi Rear
2003 Silverado Crew Cab (Black)
2500 HD 4x4/6.0L/Auto/Posi
Ol 67 C10 is offline
Old 05-15-2015, 12:11 AM   #2163
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Ordered five NOS lenses. Almost done buying NOS parts for cosmetics (exterior/interior/under hood). Just 3-4 pieces to go. Four if I can find a better part. Other than that piece, everything I've bought is in mint order, and I've picked up maybe 45 pieces over the last two months. All but three pieces are mint/NOS, one was replaced, one may be replaced and the other is good enough (a.k.a., I'm not blowing $300 for a mint fan shroud).
That and the painter called. He's coming over Saturday to discuss me dropping the bed off at his place. Looks like I'll have a rear frame to do, real soon. Will be nice to do some real work on this. I have this coming over the next 2-3 years. Hopefully three.
1. Drop bed off with body dude.
2. Have someone remove welded parts from rear frame (5th wheel and receiver hitch support). Grind/sand to perfect.
3. I'll prep and paint the rear frame.
4. Arrange for someone to rebuild/install steering box.
5. Hire someone to help me remove parts for removing the cab. I'm green, but will ask to help and learn. Remove interior down to metal.
6. Body dude and I mark and dismantle the body and windows. Load body (including cab) up onto a trailer and drop it off at his place............May have to move this stuff twice before bringing it home for reassembly. Once at his place and once at the paint booth.
7. I'll dismantle the front end and rebuild. Hit all accessibles, frame etc. Engine compartment was done with the engine rebuild, so a "novice's frame off". I'll also restore the inner fenders also, motor mounts etc..
8. Reassemble the truck with body dude.
9. Attach 28 pieces of molding with body dude. Weather stripping etc., mirrors, reassemble the interior. Probably have to drill for the moldings after paint and assembly, due to the cab mounts being shot.
10. Hire someone to help re install parts for the cab removal (maybe hire). New gas tank. Add new wire harnesses, re-install the A/C and get the window wash system like new.
11. Then I methodically install grill, bumpers, heat stove and final touches.
12. Blow another $1600-$2000 on tires and wheels, call it done.
I'm actually taking notes. Ha!
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 05-15-2015, 01:24 AM   #2164
In The Ten Ring
That was so funny! I was thinking "he did all that and all I got done in 6 hours was tweaking and flaring my fuel lines????"
Old 05-15-2015, 08:28 AM   #2165
zellway
zellway's Avatar
Welcome! Always nice to see new people join in the addiction....Hobby. Any questions you have ask away or use the "search" option. Just about anything you can think of someone has asked or done a good wright up on.
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline
Old 05-15-2015, 11:50 PM   #2166
Ol 67 C10
Ol 67 C10's Avatar
Here are some updates on the rust repair. Got both front cab mounts replaced. Next it will be going on the rotisserie.
Old 05-15-2015, 11:55 PM   #2167
Ol 67 C10
Ol 67 C10's Avatar
More pics
Old 05-16-2015, 01:15 AM   #2168
ole dollor
ole dollor's Avatar
having grand pa's truck is way cool, welcome to the forum from Texas, you will learn a bunch from these great guys, first make it safe and have fun with it , I like it already ..... Don
ole dollor is offline
Old 05-16-2015, 04:59 AM   #2169
In The Ten Ring
This is for last night: I fell out with the lights still on!
Yesterday was a big day: I got the rest of the new fuel line hooked up, all that is left is one minor adjustment and to put the carb back on and hook up the throttle and choke cables.
I got the gas tank lined back up and bolted down and hooked up the vent lines. All that is left there is to hook up the tank to the vent system (ran out of hose) and to hook up the charcoal canister.
The very next sunny day when I have at least one helper, I can heat up and put in the new rubber mat and if that fits well, put the seat back in. That will complete the cab and allow me to move on to the front end. I'll edit with pics later.
Old 05-16-2015, 02:15 PM   #2170
Bowtiguy
Bowtiguy's Avatar
Finally, tore down as far as shes going to get. Suspension parts are off the the blaster to save me some time. Once the firewall is patched up and painted I get to start putting all my NoLimitEngineering parts back on.
Bowtiguy is offline
Old 05-16-2015, 02:17 PM   #2171
Bowtiguy
Bowtiguy's Avatar
these babies showed up last week too...
TR6060 out of a 14' SS Camaro with 1,400 miles
LC9 from a 13' Silverado w/ 12K miles
Taking the weekend off while the family is in town. Back at it again on Monday!
Bowtiguy is offline
Old 05-16-2015, 02:51 PM   #2172
67Slider
67Slider's Avatar
Shined her up and drove her around. Might drop her into car show tomorrow.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 05-16-2015, 09:12 PM   #2173
matthamby
Yeah, my dad had a 72 Cheyenne when I was 14 till 17, I wanted it, but I ended up with an 85 cavalier, when he sold it, the transmission was messed up, so having this one is great for both reasons, grandpa bought this one new, it was a work horse, hardly a straight piece of sheet metal on it. It now has a 305 (engine swap in the late 80's), 3 on the tree, drums all the way around.
I have a good friend who is a "master" ford technician, he does a lot of work for others, he has got me a 350, turbo 400 & power steering box, just holding onto them till we are ready to put it all in, right now I'm just wanting to get it on the road and start using the old girl! I went to a junk yard today and found some nice seats in a suburban (leather, power w/heat) I couldn't get them pulled, the seats wouldn't move to allow me to get to the bolts, that's ok though, the center seat was missing, those are pretty common, I should be able to find more. I am going to create a thread to show my progress, even though it's going to be extremely slow! Thanks for the comments and for the encouragement!
Old 05-16-2015, 10:37 PM   #2174
71CHEVYSHORTBED402
Attachment 1403824
She's a beauty
Tony
Old 05-17-2015, 02:09 AM   #2175
In The Ten Ring
Made some fuel line adjustments. Mainly just added extra hose to cushion possible rub points. Also finished up the vent line.
Closed Thread
