Old 02-21-2015, 09:16 PM   #26
Naught
Naught's Avatar
Re: Just got my LS rad check it out
Originally Posted by shearjs View Post
Got mine installed last weekend using the 4 row mounts. Just some slight trimming on the rubber bushings and a quarter inch spacer under the top mounts.
What hoses did you use?
Naught is offline   Reply With Quote
Old 02-22-2015, 12:40 AM   #27
chinook411
chinook411's Avatar
I used the rad hoses from 2004 GMC Envoy. had to cut the bottom hose but top fit perfect.
chinook411 is offline   Reply With Quote
Old 05-12-2015, 06:34 AM   #28
mcmlxix
Collector of Projects
mcmlxix's Avatar
Thanks for the hint on the upper hose.
Do you have any more info ont he upper mount? Custom?
Rich
1972 K5 Blazer CST Click HERE
Old 05-12-2015, 07:40 AM   #29
jessemthompson
I was gonna order a griffin till I found out they epoxy weld it. I don't want any issues down the road
jessemthompson is offline   Reply With Quote
Old 05-12-2015, 09:26 AM   #30
mattcrp1
mattcrp1's Avatar
Whats "epoxy" welding? A quick google shows mixing two part epoxy's and it looks like glue. I have a Griffin and it looks like solid aluminum tig welding.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
