Old 05-13-2015, 12:01 AM   #1
Rykramer99
Intellitronix Gauges Install
Hello, I am looking for some guidance on how to install these Intellitronix gauges?
Rykramer99 is offline   Reply With Quote
Old 05-13-2015, 12:09 AM   #2
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: Intellitronix Gauges Install
https://youtu.be/V6Khujsqt7Y
Midway through the video is a good idea of how it was done....
You might want to fill out your profile, tell us what vehicle you're talking about and maybe include some pictures of what you're working with....
Rich
1972 K5 Blazer CST Click HERE
Old 05-13-2015, 12:37 AM   #3
Rykramer99
I am pretty new to the forum and I am still trying to figure it out. I bought the gauges off of ebay and I have a 1969 Blazer. Thanks for the help.
http://www.ebay.com/itm/67-72-Chevy-...8b942c&vxp=mtr
Old 05-13-2015, 01:28 AM   #4
mcmlxix
mcmlxix's Avatar
So no instructions? I would email Intellitronix and see if they can send you some...
Rich
Old 05-13-2015, 02:04 AM   #5
GMC-YA68
GMC-YA68's Avatar
Or ask Stacey David
GMC-YA68 is offline   Reply With Quote
Old 05-13-2015, 08:59 AM   #6
ScottTRD
Look up member Johnnyfever. In his albums, he has the instructions.
ScottTRD is offline   Reply With Quote
Old 05-14-2015, 12:00 AM   #7
Rykramer99
The gauges came with instructions but I am still having issues. I will see if I can find Johnnyfever's instructions. Thanks Gents
Old 05-14-2015, 09:09 AM   #8
Bladeboy1998
Remember, we need pics!!!
Good luck with the install
Bladeboy1998 is offline   Reply With Quote
Old 05-15-2015, 10:00 PM   #9
Rykramer99
Old 05-15-2015, 10:03 PM   #10
Rykramer99
Old 02-09-2016, 04:05 PM   #11
DaHos
DaHos's Avatar
Bump......included instructions leave a bit to be assumed........
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 05-22-2016, 01:32 AM   #12
ANTSOCL
hey, i just bought this set up as well. i have a conversion to a 94 drive train. anyone know what wire from the ecm i hook up to the speedo. i tried the brown and drk blue wire in the blue side connector. the blue didnt register any speed and the bwon said i was doing over 160mph when i was barely crawling
ANTSOCL is offline   Reply With Quote
Old 05-22-2016, 12:21 PM   #13
Speedway16
The speedo wire hooks up to the supplied VSS in the gauge kit.
Speedway16 is offline   Reply With Quote
Old 05-22-2016, 12:47 PM   #14
ANTSOCL
so i have to replace the stock sensor? the intrusctions said if vehicle already has a speed sensor to hook up to the vss wire. from all the wiring diagrams i have found online it would seem to be either the dark blue or brown wire from the speed sensor to the ecm
Old 05-22-2016, 01:10 PM   #15
Speedway16
My instructions don't say anything about an existing vss. Mine says disconnect the mechanical speedo cable and install the supplied vss. Instructions say to wire it to the white wire on the vss.
Old 05-22-2016, 01:32 PM   #16
ANTSOCL
this iS what mine say
For vehicles which have a vehicle speed
signal from a transmission sensor or ECM, tap into the VSS wire (Consult a
vehicle service manual or wiring diagram to determine correct wire color) and
connect it to the WHITE speed sending wire from the digital dash.
If your car is equipped with an electronic transmission then there will be an
electronic vehicle sender with either 2 or 3 wires coming off of it.
Old 05-22-2016, 01:59 PM   #17
Speedway16
There seems to be a lot of variations in the instructions because the colors my instructions said didn't match to the panel exactly. My manual for a 94 shows the wires going to the vss should be red/black and dark blue/white out of the ecm. They are out of ports f2 and f3 on the ecm. One should be vss power and the other would be the signal. Test to see which one has switched power and then tap into the other one. It's hard without knowing exactly how your wiring is
Old 05-22-2016, 07:59 PM   #18
ANTSOCL
on the red side plug or blue side of the ecm?
Old 05-22-2016, 11:01 PM   #19
Speedway16
It doesn't say what plug. Every wire is labeled with a letter and number on the plug itself
