Wheel fitment
Does anyone know if a 17 inch wheel will fit over disc brakes when switching to disc brakes from drums? I have a 70 c20 by the way
1972 gmc c15 short bed... Sold 1970 chevy custom camper patina daily driver |
Too many projects
Re: Wheel fitment
A 17 should fit fine, the smaller 16s are stock on 3/4 tons so I wouldn't worry about it.
If you are concerned you can mock up the rotor and caliper inside the wheel to double check while the parts are still returnable.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
Re: Wheel fitment
I've looked at a few kits to switch it to discs and they all say stock wheels won't fit. I had a 72 gmc with stock discs and 18s fit fine. I'd just rather go with a 17 and bigger tires on my current truck
Re: Wheel fitment
Stock 1970 and earlier drum brake wheels (3 nub steelies) won't fit. Modern 17's didn't come around until well into the disc brake era and should fit fine as long as they don't have a goofy backspace.
Re: Wheel fitment
What's a good backspace to get I don't want it to stic out just be even with the fender. I love my steelies they just sit in so far
Re: Wheel fitment
Disc brakes move the wheels out some. The reason the stock wheels don't fit disc brakes isn't the diameter but the shape of the center. It is not shaped to clear the caliper. 17's have the most tire sizes available and probably wheel choice as well.
Posted via Mobile Device |
#7 | |
Re: Wheel fitment
Re: Wheel fitment
Mike's right the "Center section" and the "Hoop" are too close to clear disc brake calipers, sometimes even grinding on the calipers won't help. Also the back spacing is critical as the improper offset can cause the inner rim edge to hit steering knuckles, tie rods, sway bar, etc.
68 GMC SWB Vortec 5.3 98 Chevy Blazer ZR2 94 Mazda Miata, LS2 6 speed, sold "No matter what happens, nobody gets out alive" Last edited by Lees68GMC; 05-14-2015 at 10:29 AM. |
#9 | |
Re: Wheel fitment
Roto Reuter thats the name...
![]() Join Date: Feb 2010
Re: Wheel fitment
17" Hummer wheels fit on my 69 C20 with front disc brake conversion.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
Re: Wheel fitment
That looks sick! Makes me not want to lower mine
