Old 02-08-2004, 11:24 PM   #1
low 84
low 84's Avatar
what is a carrier?
what is a carrier in a rear end. i know my 12 bolt has a 3 series carrier because it has 3.07 open gears so if i want to switch to 3.73 i need aftermarket ones to fit a 3 series carrier. but what actauly is the carrier? is it part of the spider assembly in the center of the ring gear or what??? basically reason i want to know is if i take out the spider assembly crap and go to a mini spool do i still have a 3 series carrier and need 3 series 3.73 r&p?
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 02-09-2004, 12:59 AM   #2
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
The carrier is the large rotating assembly in the rear end. The ring gear bolts to it, and the spider gears, cross shaft, and side gears are all "carried" within the carrier. Removing the spiders and using a mini_spool, leaves you with the came carrier.
Mike
NeCrOmAnCeR is offline   Reply With Quote
Old 02-09-2004, 12:59 AM   #3
TIMSPEED
TIMSPEED's Avatar
Re: what is a carrier?
I dunno about a MINI spool, but for a NORMAL spool, you'll still need the carrier, the spool goes INSIDE the carrier, which also the gears are inside. I believe the difference is the 4 series carriers are actually LARGER than the 3 series.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 02-09-2004, 01:00 AM   #4
low 84
low 84's Avatar
thanks thats what i needed to know
'05 1500 Crew Cab
RIP
Old 02-09-2004, 02:20 AM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
A mini spool replaces the spider gear assembly. A spool replaces the carrier. I personally wouldn't recommend either on a strickly street driven vehicle.
In addition, mini spools are typically not recommended for high horsepower applications. Edit: Plus, who makes a mini spool for a truck application?
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 02-09-2004, 02:35 AM   #6
low 84
low 84's Avatar
i'm not sure i'm going with one yet. just considering different things now. i was told in another post that a car mini spool will fit a truck and in jegs auburn list one for 12 bolt car/truck same pn
'05 1500 Crew Cab
RIP
Old 02-09-2004, 10:28 PM   #7
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 02-09-2004, 10:43 PM   #8
low 84
low 84's Avatar
lol
'05 1500 Crew Cab
RIP
Old 02-09-2004, 11:25 PM   #9
NeCrOmAnCeR
Good One!!
