Old 02-09-2004, 01:52 AM   #1
Scrub
Collector of rusty Items
Scrub's Avatar
Signal works, but brake light doesn't ??
Both my rear signals work, but my left brake light doesn't come on? I know the same wire feeds the same filiment for both brakes and signals.
Is there some diode that might be toasted.
It's a 70 GMC 3/4 ton
Thanks in advance.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 02-09-2004, 02:34 AM   #2
mshirey
There are two wires that feed the brake/tail lights and two filaments in the bulb. Since the tail lights are working I would say the ground is probably ok. Best guess would be a short either in the rear harness or in the intermediate harness that runs along the left frame rail.
Mike
67' GMC Fleetside
mshirey is offline   Reply With Quote
Old 02-09-2004, 03:02 AM   #3
cdowns
cdowns's Avatar
sounds like you need a new light bulb#1157
Old 02-09-2004, 08:11 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Looking liek a turn signal switch.
The parking light works off the brown wire. The brake light AND the left turn signal work off the green wire. (And the green wire only)
If the light lights up for thesignal, and not the brakes...then that proves that the wire and all connections are good south of the switch.
I can't see any way it can NOT be the turn signal switch.
Old 02-09-2004, 09:00 AM   #5
JimKshortstep4x4
Talking
I would have to agree with Longhorn. Try moving the turn signal lever while holding the brakes on to see if the lights will light up.
Jim
Old 02-09-2004, 09:26 AM   #6
tom hand
CCRider
tom hand's Avatar
Yep...turn signal switch. Try removing your steering wheel and cleaning the contacts before replaceing it....sometimes it's just dirt.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 02-09-2004, 11:58 AM   #7
TsgtE662
2A674 Tank Rat
TsgtE662's Avatar
I'd change the bulb first. Its easier and cheaper.
'92 GMC Sierra, Sportside, 2wd, 350, Black
'92 Chevy Silverado Extended Cab 4 x 4, Blue
USAFR = 2A674 = Aircraft Fuel Systems Maintenance
i.e. Tank Rat
TsgtE662 is offline   Reply With Quote
Old 02-09-2004, 12:36 PM   #8
Blue Beard
Blue Beard's Avatar
If only the left brake light isn't working, sounds like it would be towards the back.
Generally speaking the yellow and green wires are turn signal, and the brown is running lights.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 02-09-2004, 05:53 PM   #9
Longhorn Man
Some of you are not realizing that the brake light folows the exact same wire as the turn signal.
So if his turn signal works, then the bulb is good, as is the wires going all the way back to the tail light.
Old 02-09-2004, 08:57 PM   #10
tom hand
CCRider
tom hand's Avatar
The brake light IS the turn signal in the back. When you put on your blinker, it flashes the BRAKE light. So with the problem described above, the problem is going to be in the switch. I had the same problem after I painted my truck, because I had gotten some paint into the switch. Removed the steering wheel, cleaned the contacts, and it works like new.
Olive Branch MS
Old 02-10-2004, 01:06 AM   #11
Scrub
Scrub's Avatar
Thanks to all.
The old girl has over a million miles and still goes great. I guess it's time to clean up the turn signals again.
Scrub
Old 02-10-2004, 01:48 AM   #12
Longhorn Man
I knew some one on here had me beat in the mile department....I just couldn't remember who.
