61 Apache bed restoration
I need help.
I been searching and searching the web and just can't seem to find what I'm looking for. I'm restoring my bed so I will be using LMCs bed kit to do the job. Now , when I removed my bed I noticed that the side rails that look to be welded to the sides of the bed need to be replaced. The LMC bed kit comes with angle strips but to me they seem like they go on the upper side of the wood exposed. Are there angle strips for the lower half of the bed? Also what's the difference between bed strips and wear strips? LMC has both on the kit. I attached a picture for assistant. What you're looking at is the under side of the bed. Look at the lower left hand side of the picture. It's all roted out. I hope I make sense. |
Re: 61 Apache bed restoration
mar-k has info on bed installation...
Yes it does but it doesn't get in to detail regarding differences of "bed strips" vs "wear strips". As for the angle strips it explains how to remove them and install them both bolted on or welded on but it doesn't answer my question which is , are the angle strips that LMC sells correct to replace the ones I need to replace?
I attached a picture to show the area I'm talking about. Lower left hand side of the picture looks to be a rotted angle strip. I need to know if it is a angel strip or if its a different rail I need to outsource off a donor bed? |
#4 | |
Pimpston65: thanks for your input. It is a bit confusing. Im in need of the angle strips anyways so I'll be ordering my parts. I'll find out if I need some of those "shelves strips" that are on the edges. The cross sills look to be in good condition and I'm just going to restore them. LMC is good at offering every part you need I wouldn't see why they would leave out important body pieces needed for a full be restoration.
#6 | |
