![]() Join Date: Jan 2012
What should I upgrade my I6 distributor with?
I read the thread that SHIFTY did a few years ago regarding upgrading the distributor to an HEI. That seems pretty straight-forward. I was wondering if there is anything better out there now than the HEI as an upgrade?
I want to make the I6 run as good as possible while I am amassing parts for the LS change-over and doing body work. What is the latest and greatest? Right now it has the original points distributor.
Matt Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655 "Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!" |
![]() Join Date: May 2014
Re: What should I upgrade my I6 distributor with?
Nothing has changed. Some will say HEI. Some will say pertronix. Personally I prefer HEI because in case of a failure you can get parts off the shelf anywhere easily vs. having to find a replacement Pertronix unit.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
I'm runnin an hei dizzy from an 80 250 on my 72 250. Basically a bolt on and cheap too, just needed to run a new power wire, get some 8mm wires also from an 80, and regap the plugs. I really like it, I don't see how you could make it any easier than that. I went with the 80s timing too. Got the dizzy and wires from advance, something like 100 bucks. Don't use their stranded wire btw, that stuffs junk, IMO anyway.
Was the 80's dizzy have a coil on the cap? I like the price from ato zone but my 70 250 is an external coil.
I'll get you a pic if I have some time kinda bust right now
Thanks. Did you have an external coil? Is it easy to wire around?
Yes, and yes, super easy, way less complicated than these online walk troughs sound lol
I sent you a pm. Thanks.
Hey man, started to send you a long pm earlier and phone died on the last sentence lol. We'll get you sorted out in the morning. I'll get you some pics and part numbers. Whatever ya need man.
Here's a pic from the day I got my truck, factory setup, external coil, I beleive these run about 15000 v, blah blah someone correct me if I'm wrong. Factory gap was 35
What?
All points distributors have an external coil. 1975 was the first year of the HEI and the I6 used an HEI with external coil. I think it was in '77, the I6 was given the taller cap with built in coil. The first HEI I had in my 292 was one with the internal coil. The caps are not interchangeable because the locator notch is in a different place. When I was designing and building the AC compressor bracket, the height I chose, dictated the external coil so I could remove the cap, without loosening the compressor belt. That first HEI was installed in the early '90s and both have been running with the original wiring with the ballast resistor in place and unmolested. I did remove the yellow (on most) wire from the "R" terminal of the starter solenoid. In 1975, Chevy said to gap all the HEI plugs at .060". By 1980, everyone realized that instead of changing points every 10k miles, they then had to change the plug wires every 10k miles. If the introduction of the HEI did anything, it brought about a marked improvement in the quality of plug wires. By 1990, Chevy called for plug gaps of .035" for most HEI engines. New plugs will fire at around 12k Volts in most engines. As the plugs get older and the electrodes wear the required voltage rises. At higher voltages there is a tendency for misfires and spark scatter. With a .060" gap you have an even higher voltage requirement and an increased occurrence of spark scatter. By reducing the HEI ignition plug gap, Chevy was able to reduce emissions and a small increase in fuel mileage. .035" plug gaps have worked fine in my 292 for many years.
'67 GMC 2500, 292, 4spd, AC |
What? Is your point, I'm just trying to make sure he doesn't buy a an 80s cap in coil if he's got a compressor, it will be in the way of the massive cap. That's a pretty motor ya got there!
Ok most of what Richard said is true but if I understood him correctly he kept a resistance wire with an hei, everything I've ever read says to remove the resistance wire. I removed mine and advise you do the same. The resistance wire is there to allow you 12 v at startup then it drops voltage as to not burn up the old points style ignition. Newer hei ignition is designed to run off 12v all off the time so it would be a bad idea to leave in that resistance wire and he is the first person I have ever heard to leave it in. Maybe I misunderstood him. I'm going to suggest you remove all old wiring.
#15 |
Ok I'm gonna give you a quick walkthrough on how to put a 1980 hei from a 250 on your truck. Between mine and shiftys I think you'll get it figured out.
Here's a parts list 1980 stock distributor for a 250, you should be able to get one at any parts store, make sure you buy the one that comes with the cap and the coil. part number t1697 at advance $129.99 online right now Spark plug wires for a 1980, you can get a precut set from advance part number 96601 $27.99 or cut your own, they are 8mm wires 10 ft 12 gauge REAL automotive wire! (A little extra in case you mess up, wire is cheap) that stuff they sell at parts stores is just speaker wire. You want oil and gas resistant wire or what I went with, gxl wire from wire barn. About $10. A gm 56 series connector (I recommend you get a five pack in case you screw one up) (Optional) new spark plugs for YOUR 250. This is a good time to replace you plugs, I recommend AC Delco platinum plugs, I gapped mine to .040, I think shiftys recommendation was .045. Your choice. Last edited by Custom/Ten; 05-18-2015 at 11:01 AM. |
#16 |
Set your engine to top dead center and remove all this,
#17 |
Now gap and install spark plugs, install new distributor turned in whatever direction you want as long as your pointing at number 1 when your at top dead center, your balancer should read 0 on the timing tab.the bottom of the dizzy shaft should be touching the block, and the dizzy will twist a little bit as it drops in. If you have a 1/4in gap then take it back out and rotate the shaft a tooth so it drops all the way in. Don't forget your gasket.
Once the dizzys in run your wire from the dizzy to the fire wall, you don't need the wires to the starter anymore. Gm 56 series connector goes to a terminal that has power (12v) durning cranking and in the key on position. Red wire for power, green for tach. After you have that all hooked up run your plug wires, set you timing, and your good to go. |
#18 |
Forgot to mention these dizzy terminal I got from lmc for 10 bucks, they are the same as the v-8 hei. The red is power, the brown goes to my green tach wire.
#19 |
I think between me and shifty you have everything you need, only thing I wasent clear on from his is that you no longer need to run wire to the starter but maybe I just missed that while reading. His threads actually pretty awesome!
#20 |
I gotta head out now but feel free to ask any questions if I missed or was unclear on anything. If I messed anything up I'm sure someone will chime in, just be careful who ya listen to and make sure you get multiple opinions. Sometimes people tend to talk without knowing wtf theyre talking about or just have an outright brain fart. Not talkin trash because I've been guilty of it myself, everybody makes mistakes ya know so thats why I always say get multiple opinions. Good luck man, I know if you get er done you'll love it!
#21 |
Tried to edit this but was too late, don't have time to retype, READ THIS
#22 |
More pics for you
#23 |
#24 |
#25 |
Running points in my 250. Works just fine when the parts are all good. Reason so many see a vast improvement going HEI is because they are replacing worn out parts.
