Old 05-20-2015, 01:17 AM   #1
dsraven
Re: 56 step side on 07 trailblazer chassis
wow, lots of work in a short time. just curious if those tirese rub. did you reprogram the ecm for the different tire size? how do they affect cruising speed, does it bring the rpm up a bunch at 110 kph?
your truck looks good. lots of cool ideas that you thought of yourself, nice to see that instead of copycat someone else's ideas.
Old 05-20-2015, 04:55 PM   #2
rustymarco
rustymarco's Avatar
the speedometer show pretty much the real speed compare with the gps speed on the mirror but the thing is the 56 cluster just go to 100k/h ,but that can be calibrated and changed to m/h ,and the small tires take out a little bit of speed but give more hp and torque ,now is very quick and still fast i run at 125k/h by gps at normal rpm the same when gear ratio is changed now have more performance than economy but still economic compared with a classic carburated v8 ,for that im sharing my project ,i start looking for imfo. and i thing is a good idea give ideas about it
rustymarco is offline   Reply With Quote
