Old 05-22-2015, 08:28 AM   #1
smoked68
smoked68's Avatar
Sag 4 speed shifter arms
Hi guys, I have a sag 4 speed in the truck now and the shifter arms keep working loose. They seem to hit the side of trans and work themselves loose. Is there a special arm that goes into the trans for the sag? I have a hurst comp plus shifter and these arms have the normal rectangular slots on them. On the muncie I had the slot on the trans had enough of an outward flat I guess to but up against and tighten. Not so with this trans. The arms go on the sam but bottom out on trans. I need help please.
Thanks Mike
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 05-22-2015, 09:06 AM   #2
smoked68
smoked68's Avatar
Re: Sag 4 speed shifter arms
Is there a spacer that I can put on then bolt the arm to it??
Old 05-22-2015, 10:53 AM   #3
smoked68
smoked68's Avatar
Like say a small spacer with the slot in it that I can then put the arm on and run the bolt into??
Old 05-22-2015, 11:56 AM   #4
smoked68
smoked68's Avatar
appearently, an enigma wrapped in a puzzle...hmmmmm
Old 05-22-2015, 12:58 PM   #5
geezer#99
geezer#99's Avatar
Take a pic of your enigma!!
Might jog somebody awake!! LOL!!
geezer#99 is online now   Reply With Quote
Old 05-22-2015, 01:11 PM   #6
smoked68
smoked68's Avatar
I will do so tonight but ultimately it is a regular shifting arm that has the rectangular slot cut in it. The trans mates to that with the raised rectangular part. Hole in middle that a bolt threads into. On the muncie i was running same deal but a threaded part stuck up and had a nut on top. Except that the trans side had a stop on it. It stuck out trans enough to have a stop that kept it from hitting side of trans. What I am dealing with is too countersunk to tighten before it hits side of trans.
Old 05-22-2015, 01:45 PM   #7
geezer#99
geezer#99's Avatar
I got an idea what you're describing but will wait for pics.
Old 05-23-2015, 09:23 AM   #8
Yeah, definitely need pictures on this. I have a Saginaw complete set-up I can compare to. Gotta see if it's all there. Could be you are missing a spacer or something isn't assembled quite right.
Old 05-27-2015, 12:19 PM   #9
smoked68
smoked68's Avatar
Thanks for input, Im building a house and was caught up with all that aggravation the last 4 days. Ill get a pic soonest. Today hopefully. I thank you all
Mike
