![]() Join Date: Nov 2013
My 71 GMC Stepside short wheelbase has a 2 piece Driveline. Should I go 1 piece driveline,
Re: Driveline Question
Is there a problem you're trying to solve? GM didn't use extra parts when they didn't need to, so there's some benefit of a two-piece, or at least they thought so at the time...
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
![]() Join Date: Apr 2014
I have a one piece I would trade ya if you want a one piece. I cant run it due to it hitting when I air my truck out. PM me if you are interested.
'70 2wd swb, 406 sbc, air ride and a big smile on my face! |
#4 | |
https://www.google.com/search?q=chev...0drop%20member A certain amount of change can also be had by removing the rivets holding the front trailing arm brackets to the cross-member and either moving it up or down by drilling extra holes or turning it upside down, just depends on how you need to go and how you want to do it. Shimming the pinion angle of the rear axle pads is probably the easiest way to go for minor adjustments. As you see in the pictures, wrongs and rights. The R side picture with the red frame/tires, A is incorrect and B is correct. |
#5 | ||
Previous discussion: Quote:
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Alot of good input, I plan to drop the rear 4", 2" with springs & 2 with blocks. Which is a good combination springs & blocks ? Also going 4" is 1 piece or 2 piece Better with this drop ?
Don't think we missed anything based on your post.
It's a short wheelbase as specified by the OP. On light trucks, the only 2pc drive-shafts on this era truck that I have seen have been on trailing arm suspensions, and I always assumed (gulp), that it was because of the pivot point of said trailing arm mounting point and the associated geometry. That being said, I would like to ask you a question: How does the stability of the pinion angle of the trailing arm C10 suspension relate to the 2pc vs 1pc driveshaft in regards to stable angles throughout suspension travel? Is a 1pc a bad choice if the trans tail-shaft is forward of the trailing arm pivot point? I believe it travels in an arc vs the somewhat erratic movement of the pinion of the light truck leaf spring rear axle (axle wrap, shorter pivot point). Interesting NASCAR has used this type system, I think they used 1pc drive-shafts but not sure where they located the trans tail-shaft in regards to trailing arm pivot point. |
#8 | |
The fact that the two components (drive shaft and rear suspension) are traveling on different arcs is immaterial because the change is taken up in slip at the slip yoke. For example, the difference in attaching points is even more dramatic on a leaf spring equipped vehicle vs a trailing arm suspension (and doesn't cause a problem). If I understand your comment/question correctly - K
