Old 05-22-2015, 03:39 PM   #1
papsoldblue72
papsoldblue72's Avatar
Question Gas cap issues....
Has anyone on here ordered a factory replacement gas tank only to find out that when you get it the original cap doesn't fit ???? The filler neck on the repo tank is larger then my original....... What cap will work?????? Where can I get one ????? Everyone I find for a 1972 EEC tank is too small .......
It's been a long time coming... It's time to get it done..
papsoldblue72 is offline   Reply With Quote
Old 05-22-2015, 05:06 PM   #2
Tim Christian
Tim Christian's Avatar
Re: Gas cap issues....
Do you know if you got Part #GM49A #GM49B or #GM49C ?
Tim Christian is offline   Reply With Quote
Old 05-22-2015, 05:13 PM   #3
54blackhornet
54blackhornet's Avatar
Don't buy a NAPA cap, the rubber seal falls apart in no time at all.....
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 05-22-2015, 05:14 PM   #4
leftybass209
leftybass209's Avatar
You can check the cap for a 70 and older tank. They didn't have eec.
leftybass209 is offline   Reply With Quote
Old 05-22-2015, 08:58 PM   #5
cericd
cericd's Avatar
Who makes one with a rubber gasket that doesn't fall apart in no time?
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 05-23-2015, 07:56 AM   #6
papsoldblue72
Well I found on another thread that someone got one for a 70 model and it worked so I did the same.... I got it on last night and it is really tight .... I also don't have the EEC all hooked up.... Where the line comes to the fuel pump on the frame rail I just ended it there because my fuel pump was a one line hook up deal..... Will this cap cause me issues????
Old 05-23-2015, 10:27 AM   #7
cdowns
cdowns's Avatar
if it is vented it will work ok if it is not vented and you have no vent in the tank you'll have problems
Old 05-23-2015, 12:11 PM   #8
ho70
ho70's Avatar
I have a new EEC 72 tank I installed last year. The 72 cap didn't fit so I bent the tank opening, only to find here that they use a pre 72 filler neck on the new 72 tanks (cheaper to use only one filler). Try a 70 cap and it will be tight but fit
ho70 is offline   Reply With Quote
Old 05-23-2015, 12:36 PM   #9
leftybass209
If there's no vent your tank will swell up. Mine swelled and started leaking into the cab, but I caught it just as it started.
Old 06-17-2015, 02:08 PM   #10
papsoldblue72
Thanks ho70 it works but tight like you said....
gas cap
