#26 |
meowMEOWmeowMEOW
Re: The 60-66 "PAYING IT FORWARD" thread!
Glad this worked out Jay!
I've got a tub of misc to go thru and toss on here.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#27 |
I am liking this idea. Cleaning garage this weekend. Two clean 15 x 5.5 OEM 6 lug wheels, RED. (they were listed in for sale section) Two like new NAPA gas shocks for rear of C10. On only a couple months and went to air shocks. Original fan shroud off of my 66 burb. A couple little pieces out of it. Will get pics later today. You just pay the shipping on any of these. Thanks Jim
#28 |
Registered Loser
Great idea for a thread.
I have a full front crossmember with suspension, spindles and brakes from my 63 GMC 3/4 ton just chillin' in my garage.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
#29 |
My 66 burb shroud is for a V8. J
#30 |
But Found Her 25yrs Later!
I'll take the Shroud Mr 1966 burb
#31 |
Could this thread be stickied?
I have the original dash cluster for a 62 (fuel gauge, warning lights) with the cluster harness if anyone wants them.
1965 C10 Longbed Stepside 1969 Chevelle Malibu 1962 C20 Fleetside - Build Thread (Sold before I could finish) |
#32 |
Never Ending Projects
I am going to sticky this for now.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#33 |
Moderator
![]() Join Date: Dec 2012
I'm honoured at the response to this thread. I hope we can all benefit from our crowded garages as well as our collective generosity.
#34 |
![]() Join Date: Sep 2013
Here are a few 1964 C10 items that need a good home.
Brake Master cylinder taken from a running truck Pair of blasted and epoxy primed steering arms Rear lower shock mounts |
#35 |
Steering arms
#36 |
Rear shock mounts
#37 |
I need one. I'll pm you.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
#38 |
Not sure if the speedo works. The yellow thing looks a bit wonky.
#39 |
Scott 63 C10 Stepside 230 1bbl Saginaw 3 spd |
#40 | |
Projects: 65' Chevy C10 swb (rebuilt chassis) 65' Chevy Panel swb 64' Chevy C30 flatbed "above" 80' C30 "beneath") Parts: 66' GMC 2503 & 65' GMC I1500 |
#41 |
This is a great thread. Like grizz said I have given parts to him and he has returned the favour . Once I build up my chassis I should have a few standard parts . Rian (grizz) has already had the break lines .
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=611614 |
#42 |
I have the remains of of a 65 gutted low hump cab. No doors, the rockers, cab corners and most of the floor are shot. I cut the roof off for my project. If anyone needs any other cuts let me know they are yours. I will post pictures per requests. Ask about cuts now, any remains are going to the scrap yard next Friday.
#43 | |
#44 |
It's a shame you are so far away,as I am cutting up my old cab into repair sections (vacation ) is the answer my self and Rian are using ours as a shopping trip
#45 |
THIS IS OBVIOUSLY FOR UK MEMBERS
But anyone is welcome to them. Right..... Hope I do not regret giving these away later if I end up needing them. I have some 60-66 parts, all good for donor sections to other trucks. There is rust, holes , bodges etc. THEY WERE TAKEN FROM MARTIN'S 1965 C10 ![]() ![]() NO.... I did not cut the hole in it. ![]() ![]() ![]() ![]() PLEASE NOTE: These parts are for Collection only, I really do not have time to sit about and wait for couriers. Please PM your interest. If they do not go, they will stay on top of the wood shed behind the garage, to be used later.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
#46 |
i so need the both cab support rails and a few section of the firewall, will travel to you!!!
pimpston65, are these the cuts we talked about? I believe the red circles show what you want. Do you also want the sections I circled in yellow? Or is there some other cut you want? |
#47 | |
#48 |
Weather permitting I will cut this afternoon.
#49 |
I have 2 old spiral shocks that came off my 65, they need to be rebuilt and painted but I hear some guys that do restorations look for these to be original , just throwing them out there free to a good home local pick up preferred. I'm located in south San Diego. I have other stuff I just need to go through my piles and make sure what I'm going to use or not.
#50 |
Re: The 60-66 "Pay It Forward" thread!
| Bookmarks |
