Old 05-22-2015, 05:11 PM   #1
leftybass209
leftybass209's Avatar
$$ forced into a 1 piece driveshaft! ;)
Here's the story:
Today I took my 2 piece down to have new u - joints installed and have it balanced. It was going to be $180 which I thought was reasonable. When I got down there I discovered the center yoke that bolts on had a 3/4 inch chunk missing around where the keeper rides in the groove. After a discussion with the employee he said, "there is strength there, but who knows how much". I agreed and asked if he could get another. He called around and found 1 for $116 which we both thought was high. I knew I could get one from the parts board here, but thought I'd ask about a 1 piece. He quoted me $265. So seeing the difference between 296 and 265, I decided on a 1 piece. I went home to measure about 10 times to verify the proper length. Best part, he was slow today, and I'll have it later this afternoon. I'll post some pictures when I get it.
I guess the moral of the story is, don't beat your u - joints in with a hammer. I didn't see the chunk missing initially because it was rusted and dirty, and blended in.
leftybass209 is offline   Reply With Quote
Old 05-22-2015, 05:28 PM   #2
Money_pit
Money_pit's Avatar
Re: $$ forced into a 1 piece driveshaft! ;)
Just what I'm looking for too.
71 C10 Finally took a leap and did the 5.3 4l80e swap.
Running the Holley Terminator Xmax. Still working bugs out.
Money_pit is offline   Reply With Quote
Old 05-22-2015, 09:01 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: $$ forced into a 1 piece driveshaft! ;)
I had a one peice installed back when I did the LS 6.0 and 4L80E. Best thing I have done. Mine is static dropped. That's a good price mine was $495.00 installed.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-23-2015, 10:19 AM   #4
Bowtiguy
Bowtiguy's Avatar
you guys BOTH got off cheap, It looks like mine will be $750 for that funky 3 bolt flange output off the 5th Gen F-body TR6060 back to my 1350 upgraded pinion yoke in the 12 bolt.
Bowtiguy is offline   Reply With Quote
Old 05-23-2015, 10:50 AM   #5
70blackfish
lefty is your truck a long bed or short?
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 05-23-2015, 12:15 PM   #6
70shortfleet
70shortfleet's Avatar
I must have got lucky also, I just had Certified Power here in Bridgeton, MO make me up one for my big block GMC and it was on $233.94 and it took out the vibration I was getting!
70shortfleet is offline   Reply With Quote
Old 05-23-2015, 12:33 PM   #7
leftybass209
It's a short fleet. The grand total was $288 even, with u bolt straps. Took the guy right around 2.5 hours to finish it. Got home, lopped off the carrier mount and it fit perfect.
Old 05-23-2015, 01:40 PM   #8
70shortfleet
It's great when things work out the way you want them to!
Old 05-23-2015, 01:45 PM   #9
geezer#99
geezer#99's Avatar
Hope you checked the pinion angle first!!
Old 05-23-2015, 03:27 PM   #10
leftybass209
Pinion angle is fine.
