Old 02-08-2004, 01:54 PM   #1
BowTieMan
BowTieMan's Avatar
Guage Question
I was looking at a picture the other day and I was wondering. Could I change all those guages to an after market set? Something like AutoMeter or something?
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 02-08-2004, 02:05 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
yup. I did the acc guages only...I think mudder did his whole dash.
Old 02-08-2004, 03:06 PM   #3
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
Yep...
I had an original dash before I started building this one. Pretty easy project.
FuelCellGuy is offline   Reply With Quote
Old 02-08-2004, 03:34 PM   #4
Mudder
Mudder's Avatar
Here's mine
5inch
3 3/8
2 5/8
Mudder is offline   Reply With Quote
Old 02-08-2004, 03:53 PM   #5
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
fcg i must ask what are you going to do with all those gauges?
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 02-08-2004, 04:28 PM   #6
FuelCellGuy
FUEL CELL GURU
Here we go...
Of course, 5" tach, 5" speedo; 2 3/8" volt, fuel level, water temp, oil pressure, vacuum, and trans temp; 2 1/16" air pressure (x5)- 1 for each air bag and 1 for the tank. It may very well look like a pilot's cockpit when it is done. It ought to look pretty good.
Old 02-09-2004, 01:54 PM   #7
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
Geez FCG, that's a lot of information (not to mention a lot of $$$ in gauges )
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 02-09-2004, 02:09 PM   #8
junkyardjohn
junkyardjohn's Avatar
HERES A SET I'M BUILDING FOR MY LATEST VICTUM.
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 02-09-2004, 02:11 PM   #9
FuelCellGuy
FUEL CELL GURU
Well..
it won't be too bad $$$-wise. I bought 7 new gauges for $100 from a buddy. I kept the ones I need and sold the others on ebay. I ended up getting 4 gauges I needed and $80 for the ones I didn't need.
Old 02-09-2004, 03:39 PM   #10
miket
miket's Avatar
How are you guys wiring these? Are you keeping the plug harness that plugs into the circuit panel?
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 02-09-2004, 04:19 PM   #11
FuelCellGuy
FUEL CELL GURU
Well...
I.....
Old 02-10-2004, 04:23 AM   #12
Mudder
Mudder's Avatar
I used the wires for the turn signals, and dimmer switch from that harness.
Old 02-10-2004, 03:24 PM   #13
gr8scott51
gr8scott51's Avatar
Painless
I bought the Painless universal dash wiring harness so I can unplug it for easy removal of my Boese Engineering billet dash.
scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 02-10-2004, 03:47 PM   #14
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
You can also go this route very beautiful piece of work...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 02-10-2004, 05:14 PM   #15
gr8scott51
gr8scott51's Avatar
Just remember the $189 doesn't include gages! LOL Scott
Old 02-10-2004, 05:18 PM   #16
SWEET7T
SWEET7T's Avatar
Why is that water temp gauge black, and the others are white in that last post I would want a matching...
Also... Would getting another glove box door and installing gauges in it fit?! Just grab a nice hefty hole saw set, and cut some holes in it. Mount them up, do something fancy for the steering column, and put a couple of holes in it to mount it to the dash...
SWEET7T
Old 02-10-2004, 05:37 PM   #17
miket
miket's Avatar
Thats exactly what I want and need except with all white gauges...I will probably need one or two more gauges than whats there...I will have to make a list...
Yup vacuum and trans temp...
