Old 05-23-2015, 09:49 PM   #1
albertgen
Motor
Who makes the best motor? I was thinking of putting a new 350 in my truck to replace the 305 engine. I know there is a big range of prices. I will probable go for the middle of the road in price? Thanks, Al
albertgen is offline   Reply With Quote
Old 05-23-2015, 10:00 PM   #2
1979-square-body
1979-square-body's Avatar
Re: Motor
Pull a 350 from a junk yard and build it up with a cam, set of heads, headers and so on. Best motor made is your own
1979-square-body is offline   Reply With Quote
Old 05-23-2015, 10:16 PM   #3
MountainGoat1966
Re: Motor
Personally, I don't 100% trust any engine I didn't build myself.
If you have the tools and knowledge to build one, I would recommend that way.
If you are going to spend money and buy one, it's a roll of the dice no matter where you get one.
Even the best engine builders occasionally have a bad day or piece of equipment not working properly.
"Off the grid and on the seven day weekend plan"
"One person cannot know everything, but between all of us, there isn't much we don't know."
MountainGoat1966 is offline   Reply With Quote
Old 05-23-2015, 10:32 PM   #4
albertgen
Re: Motor
I understand, but I don't think I could trust an engine I built. Ha Al
Old 05-24-2015, 09:44 AM   #5
naphtali5725
naphtali5725's Avatar
Re: Motor
middle of the road price means how much? what's your budget? what do you want it to do? daily driver, towing etc. etc.
do you want a complete ready to drop in engine? or just the long block so you can hang all your parts on it?
need a little more info
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 05-24-2015, 10:49 AM   #6
Zane M
Re: Motor
If I didn't have engine building skills, I would buy a crate motor from GM.
Zane M is offline   Reply With Quote
Old 05-24-2015, 11:03 AM   #7
TwoFiftyShifter
Re: Motor
I will be replacing the tired 305 in my truck with a crate from GM. Stuck between the $1500 Goodwrench 350 or $3000 350HO. $1500 can buy me a lot....
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 05-24-2015, 01:12 PM   #8
MikeB
MikeB's Avatar
Re: Motor
Absolutely!
And even the base 350 Goodwrench engine for approx $1500 will make you grin compared to a worn out 305.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 05-24-2015, 01:31 PM   #9
albertgen
Re: Motor
It would be a daily driver, probably not more than 3000.00. Thanks, Al
Old 05-24-2015, 01:32 PM   #10
albertgen
Re: Motor
Drop in for me, small block is fine. Al
Old 05-24-2015, 03:15 PM   #11
mattcrp1
mattcrp1's Avatar
Re: Motor
That's a great price. You would be hard pressed to build one for that kind of money and have a warranty (I assume there is a warranty).
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 05-24-2015, 05:20 PM   #12
naphtali5725
Re: Motor
talk to Matt over at engine factory dot com
My build thread...
Disabled Veteran
Old 05-24-2015, 05:33 PM   #13
king-918
king-918's Avatar
Re: Motor
If you were closer I'd sell you mine. I built a zz430 clone with a th350 TCI street fighter kit and 2800 nitrous stall
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
