Old 05-25-2015, 04:09 PM   #1
BigRed76
BigRed76's Avatar
4WD Front hub question
Earlier today I tore down the front brakes/hubs on my K2500 to replace the rotors, and when I got everything apart I noticed that the right side had a shim on it that the left side did not. The shim was underneath the outermost piece with the dial in it. I'm assuming that both sides should have this shim correct? And are there supposed to be any gaskets or seals between the sections of the hubs? The last person to have this apart just put a thin layer of silicone, which worked fine, I'm just curious about the correct way these should be sealed up. Thanks for any info (And no I don't have an assembly manual to look this stuff up)
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 05-25-2015, 04:17 PM   #2
SS Tim
SS Tim's Avatar
Re: 4WD Front hub question
That is one of two gaskets per side the factory used.
In this case the assembly manual would not be of any help but the service manual will be.
If you don't have it here is a link to a usable free copy.
RTFM ... Read The Factory Manuals... download 'em here
SS Tim is offline   Reply With Quote
Old 05-25-2015, 06:29 PM   #3
BigRed76
BigRed76's Avatar
Thank you for confirming that Tim. I suppose nobody reproduces these either huh?
Zach
Old 05-25-2015, 06:58 PM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
#1 is the metal gasket shown in the pic and #3 is the missing paper gasket. Neither reproduced and difficult to find.
Old 05-25-2015, 06:59 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
PM sent
Old 05-25-2015, 07:52 PM   #6
undertaker72
undertaker72's Avatar
bigred76 if you cant round any up give me a shout I have a few down here
undertaker72 is offline   Reply With Quote
Old 05-25-2015, 11:01 PM   #7
BigRed76
BigRed76's Avatar
I was able to get the metal & paper gaskets on eBay. Thanks for the heads up DeadheadNM.
Zach
Old 05-25-2015, 11:23 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Nice! Those were a good deal. Hats off to Kevin for stepping up with his offer. Glad you're set. Pete
