05-26-2015, 12:49 AM | #1 |
64 heater control valve
My 64 C10 has a working fan motor and switch, but it looks like it never had the heater control valve that shuts off or turns on the flow of water through the heater core. I don't want to hack up my dash to put in levers. How could a control vale be hooked up? It looks like now all I can do is open and close vents.
05-26-2015, 08:25 AM | #2 |
Re: 64 heater control valve
i don't think you will need to hack up the dash. it should be a removable plate. then you can install a delux heater control with no cutting.
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
05-26-2015, 11:49 AM | #3 |
Chevy addict
You can also install a shut off or bypass valve in the heater hoses.
