05-23-2015, 12:51 AM | #1 |
73 international harvester with c10 suspension
What up every one im new here but i been building my harvester for 2 years and is my daily driver i got c10 suspension in front i subframed it cutting and putting c10 crossmember i also cut lca shortened 3/4 and raised 1 1/2 worked our perfect on rear trailing arms ran on side of frame with upper link bars cnotch it lays on frame i cant get pics to post when i press choose file it does nothing
05-23-2015, 06:51 AM | #2 |
Re: 73 international harvester with c10 suspension
Try signing up for http://photobucket.com/ its free,Upload your pictures there and anything you want to post on any forum just copy and paste the img link.
05-25-2015, 05:42 PM | #3 |
we need to see these pics!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
05-25-2015, 07:30 PM | #4 |
I have pics in my gallery i cant get it to upload on my post
05-25-2015, 11:13 PM | #5 |
Never Ending Projects
I saw this in your profile. I assume this is the truck.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
05-26-2015, 12:00 AM | #6 |
Yes that my truck i been tryn all day to put pics up but only can put pics in my gallery for some reason i push choose file here and it does nothing when i select choose file
05-26-2015, 01:57 AM | #7 | |
meowMEOWmeowMEOW
By using off-site hosting, you can put WAY more images into one post. It also helps our servers run faster by only needing to transmit a few characters as a link, instead of the full size of the image file. If you want to upload just a few pictures, by all means use the gallery....but if you want to upload a ton, or use them on multiple forums/places, its much easier to host them somewhere like photobucket and just paste the links here.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
05-26-2015, 02:34 AM | #8 |
K thanks im pretty much got most of pics in gallery already
05-26-2015, 10:55 AM | #9 |
What you can do is go to your gallery, click on the pic to open it, then Right Click and choose Copy Image Location. Then you can come back to this post and use the IMG tags. Example is [IMG]url location you copied[/IMG] Here is how it works with one of your pics.
05-26-2015, 11:42 AM | #10 |
05-26-2015, 11:47 AM | #11 |
05-26-2015, 11:49 AM | #12 |
05-26-2015, 11:51 AM | #13 |
05-26-2015, 11:57 AM | #14 |
05-26-2015, 11:59 AM | #15 |
