Old 05-25-2015, 01:35 PM   #1
old Chevy guy
old Chevy guy's Avatar
cant find rear brake hose!!!
Im changing out all the brake and fuel lines on my 71 C 20 before I put on the new cab. I cant find the correct rear flex line for my truck. It bolts to the rear axle on top of a bracket bolted to the rear cover and has a junction built in that has 2) 7/16 20 female holes the other end is horse shoe clipped to the chassis also with a 7/16-20 female hole to accept a 1/4'' steel brake line. Has anybody else had a problem finding this? does anybody have a part number? Here's some pictures. It has rear leaf springs.
old Chevy guy is offline   Reply With Quote
Old 05-25-2015, 02:57 PM   #2
SS Tim
SS Tim's Avatar
Re: cant find rear brake hose!!!
Did you try NAPA?
Often on a replacement hose for an application like this you will have to add a tee for the left right hard axle line split.
As far as I can tell its one of these two P/Ns.
...0257
...9747
Unfortunately both are listed as discontinued and I cannot find a supercession either.
www.gmpartswiki.com/query
SS Tim is offline   Reply With Quote
Old 05-25-2015, 03:12 PM   #3
FirstOwner69
FirstOwner69's Avatar
Rock Auto lists several options. If nothing else, you can get part numbers by looking at their website. For example,RAYBESTOS Part # BH36684 for $5.46. They also have pictures of the hose and show a length of 18.32".
http://www.rockauto.com/info/27/BH36684-10__ra_p.jpg
http://www.rockauto.com/info/27/BH36684-11__ra_p.jpg
http://www.rockauto.com/info/27/BH36684-1__ra_p.jpg
FirstOwner69 is offline   Reply With Quote
Old 05-25-2015, 03:53 PM   #4
7tee
7tee's Avatar
Got mine at Auto Zone...
7tee is offline   Reply With Quote
Old 05-25-2015, 04:19 PM   #5
old Chevy guy
I tried Napa but they only showed the one with the single male end at the axle. Auto zone only had that same one too. First owner 69 you have the winner from rock auto, just ordered it. Thank to all, another problem solved by the Chevy , GMC truck community.
Old 05-26-2015, 04:35 PM   #6
67 cst swb
67 cst swb's Avatar
Raybestos lists 4 different lengths.
Rear Center hose; 22.31" length - BH36542 - appear to be no T
Rear Center hose; 20.50" length - BH36683 - appears to be a T hose
Rear Center hose; 18.69" length - BH36564 - appear to be no T
Rear Center hose; 18.32" length - BH36684 - appears to be a T hose
My Trucks:
Current Project
1968 Chevrolet Short Wide Box 327 TH400 9" w/3.90 gears, paint will be White
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 05-26-2015, 07:30 PM   #7
leftybass209
leftybass209's Avatar
I got mine at autozone, and it was an exact match, but about an inch longer which didn't matter.
leftybass209 is offline   Reply With Quote
