Rear end vibration
My 72 half ton has had a vibration since I bought it.I finally tracked it down its in the rear end.Any advice would be helpful. Thank you.
![]() Join Date: May 2013
Re: Rear end vibration
Tires , shocks , bushings , axle bearings ,,, are what I would check first
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#3 | |
You could try measuring how high off the ground it sits. Then jack it up and remove the tires. Put the lugs back on the drums to hold em in place as well as balance. Then lower the rear end onto jack stands about the same height and chock the front wheels. Put it in gear and up to speed. See if it's still vibrating. If not it's in the wheels and or tires. If so, it's deeper. Might want to go to a rear end shop for an estimate.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
