66 Cab Floor repair parts list - need help
I was going to place an order soon for repair panels buy and before I did thought I'd ask you guys whats the usual order for a floor like this
![]() ![]() ![]() ![]() ![]() I had years ago bought these floor panels thinking that one day I would fix it. Then as I looked closer the floor pan it doesnt seem to extend far enough to repair the holes that are where the floor angles up under your feet. Is there a panel to repair that portion or just find some scrap metal and cut to fit? ![]() I also bought a cab corner and rocker panels. The 2 other metal parts were in the photo but are just moving box braces for hanging clothes on. ![]() Besides what parts I have, what other parts will I need to get the job done you think? I was on top bananas site and this part seemed like what I need http://www.topbananaparts.com/driver...r-section.html and maybe these http://www.topbananaparts.com/driver...ot-well-1.html I am planning to get the cab sandblasted in a few weeks and wasnt sure also if I should go ahead and cut out some areas so the blaster can get to more of the rust. Any pointers on that would be appreciated. |
Re: 66 Cab Floor repair parts list - need help
You'll probably need outer rockers as well. And check under the truck.....if the floor looks like that the cab supports may be due to be replaced.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
just make sure you look over everything twice .. because if its me, I just dislike waiting for part(s) at when its going together
esp. the support(s) ( as mentioned already )
dont want to hear excuses, i want to hear solution(s) |
#4 | |
![]() Join Date: Jul 2010
www.nsanehotrodz.com customerservice@nsanehotrodz.com 865-761-0460 Tennessee's #1 HotRod Shop! |
