Old 05-27-2015, 02:46 PM   #1
ol_skool_chevy
ol_skool_chevy's Avatar
Drop spindles
Are drop spindles the same on 1/2 and 3/4 ton trucks? 1990-97
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 05-27-2015, 02:55 PM   #2
creep
Registered Loser
creep's Avatar
Re: Drop spindles
You may be able to use 1/2 ton drop spindles on a 3/4 ton if you swap ball joints. Not totally sure on that one though.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 05-27-2015, 03:23 PM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Drop spindles
It depends on if the 90-97 are light duty 3/4 ton or heavy duty 3/4 ton. The LD version uses the same spindle as the 1/2 ton but uses 6 lug rotors instead of 5 lug. The HD spindles are different and use only 8 lug rotors.
With the LD version, you can swap between 5 or 6 lug with just a factory rotor change. To use these though, you have to use a 63-87 3/4 ton lower arm to fit the later model ball joint.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
