Trans Tunnel: To be removable or not?
I am working on a 55 1st series on an s10 frame with a Vortec 5.3 and 4l60E. I have had to cut the floor and firewall for a trans tunnel and I planned on making it bolt in (in case I have to access the transmission or for easy access to unbolt the trans if I have to replace it.) It seems a lot easier to just weld it in and deal with the trans access later. Thoughts? Anyone doing it one way or the other?
Re: Trans Tunnel: To be removable or not?
You had to cut floor & firewall?
You must be slinging it further back than I have mine... I'd just weld it in. It's not hard to pull radiator & grill off of these trucks & yank the powertrain as one big piece. Alternately, drill undersize holes in the floorboard and firewall & clearance holes in the trans tunnel and use sheet metal screws. A #12 should do.
"Over my head" 1957 Chevy 3200, big rear window & 6 lug. Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina. |
yossarian, thanks those are both good options. I do have the engine pretty far back and it sits pretty high as well. Not to mention I am mounting the cab very low.
Steve, do you have a build thread for your swap?
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies 53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793 http://67-72chevytrucks.com/vboard/s...d.php?t=771679 |
I do... but it is far from updated. I need to find more time!!! I can barely find time for the build lol. Hopefully I can get a chunk of time to update so that everything is current.
http://67-72chevytrucks.com/vboard/s...d.php?t=648779 |
thanks, same question crossed my mind yesterday.
have a lokar trans mount shifter and hand brake, access from above is help full although one piece carpet is not possible. |
I was planning on doing the same thing myself. I was thinking of making an insert that looked something like this:
http://www.progressiveautomotive.com...3/02/CV225.jpg I was going of flange the firewall like the floor and making it removable. |
