Closed Thread
Old 05-25-2015, 03:00 PM   #1051
TJ's Chevy
TJ's Chevy's Avatar
Re: What did you do to your truck today part III
Reset the points on crustine's dizzy today. .016 is the recommended gap...I think I had them at some .024. lol Might be why she idle a little rough sometimes. New dizzy on its way though.
TJ's Chevy is offline
Old 05-25-2015, 04:07 PM   #1052
LDO
LDO's Avatar
Originally Posted by jbgroby View Post
Got the steering on finally
Like the dash insert? More info please?
LDO is offline
Old 05-25-2015, 04:15 PM   #1053
LDO
LDO's Avatar
Here's what I did!
Started with the first picture.
Ended with the last two pictures. Believe it or not, progress was made. I probably have one more treatment before all the old paint is gone, then some primer to keep it from flashing over before the raptor liner goes on.
Now I gotta figure out what holes to keep!
LDO is offline
Old 05-25-2015, 06:20 PM   #1054
iceship
It's not my truck, but it's going to free up some space and get tons of use. .. old Island out of kitchen who know...
iceship is offline
Old 05-25-2015, 06:29 PM   #1055
Lugnutz65
Lugnutz65's Avatar
Originally Posted by LDO View Post
Here's what I did!
Been there brother! I can feel your pain. LOL!
I bought a bunch of the plastic plugs that are used to hold the OEM style pad in place. I plan to use the plugs until I figure out (like you) which ones are keepers. Needless to say, it's a slow process. I can shoot you some pics of my 1965 firewall in different stages of reassembly so you can tell what goes where. Just shoot me a PM with your email.
Why do you have a BIG square hole where the "through the firewall" main connection goes?
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 05-26-2015, 01:27 AM   #1056
schpeen
schpeen's Avatar
Installed traction control to the bed
schpeen is offline
Old 05-26-2015, 07:48 AM   #1057
LDO
LDO's Avatar
Thanks I appreciate that! Ahhh, yes, the awesome PO Mod hole that you are referring to is a special option that was only available on one truck. So I have a rare truck indeed. Not really, the po cut a ginormous hole to fit some fuse panel there. The wiring on this truck looked like a monkey on crack did it.
LDO is offline
Old 05-26-2015, 07:53 AM   #1058
Lugnutz65
Lugnutz65's Avatar
I can trace a pattern for that area in case you want to make a repair that will match the way it was from the factory. Lemme know.
Old 05-26-2015, 07:57 AM   #1059
LDO
LDO's Avatar
thanks alot but another member here sent me a section of firewall for me to weld in. Pretty cool deal actually.
PM on the way.
LDO is offline
Old 05-26-2015, 10:56 AM   #1060
Chevy Fleetside
Chevy Fleetside's Avatar
I only kept a few holes. Since I used a different gas pedal I used the old linkage hole to feed my wires to the engine.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 05-26-2015, 11:30 AM   #1061
TJ's Chevy
TJ's Chevy's Avatar
Pictures of the P/b booster offset mount for Lugnutz. No that's not a brake fluid leak. lol
Old 05-26-2015, 08:35 PM   #1062
jtrichard
NOT all today but getting more done on 63 GMC V6 to 350 swap and a few updates like headlight relays, daytime running headlights (low beam on with key and switches to park lights when light switch is pulled on) (relays are so nice) built my own engine wiring harness, found a nice flex line for the HYD.clutch, installed horn relay, horns from a 80 Oldsmobile (behind headlights/grill)
jtrichard is offline
Old 05-27-2015, 04:13 PM   #1063
pimpston65
pimpston65's Avatar
welded and ground down my original worn out clutch bits
pimpston65 is offline
Old 05-27-2015, 04:31 PM   #1064
TJ's Chevy
TJ's Chevy's Avatar
Looks like the throttle shaft from here. lol
Old 05-27-2015, 05:27 PM   #1065
jtrichard
Good for another 200,000 miles...... nice job
Old 05-27-2015, 05:43 PM   #1066
OldChevy61
OldChevy61's Avatar
Picked up a set of 462 heads to go with the short block from last week.
OldChevy61 is offline
Old 05-27-2015, 08:24 PM   #1067
wilbur46
wilbur46's Avatar
I'm such a freekin cheapskate that I dismantled 2 fuel tank senders and made 1 that worked!
They were both in a junk pile, but one had a broken fitting, and the other had a rusty resistor assembly.
10 minutes later---Tah-Dah!!
wilbur46 is offline
Old 05-27-2015, 08:58 PM   #1068
jtrichard
You cant do that with the junk they build today LOL
Old 05-28-2015, 07:43 AM   #1069
pimpston65
pimpston65's Avatar
yeah, are parts i'll call them "old" parts. i call parts of todays vehicles "junk" parts!!!
Old 05-28-2015, 07:45 AM   #1070
pimpston65
pimpston65's Avatar
they do look simular, but the other end of this rod isnt threaded its that same as the pic. i just shiwed one end for detail sake...
Old 05-28-2015, 08:18 PM   #1071
Chevy Fleetside
I ordered these knock offs and tried them on today. I just don't like them. They look a little better with the trim ring but still not that much. Back they go.
Old 05-29-2015, 02:07 PM   #1072
iceman777
iceman777's Avatar
after 5 long months my truck past an m.o.t,this is what we have to have in England, so after sorting out the turn signals,horn ,front lights,new hand brake to go with the power brakes,it is on the road,now im gonna driver the arse off it
iceman777 is offline
Old 05-29-2015, 02:15 PM   #1073
1963c-10
1963c-10's Avatar
Agreed. I think if they didn't stick out so far they'd look much better. But I have always wondered how they'd look on our trucks.
1964 Short bed trailer
1963c-10 is offline
Old 05-29-2015, 02:30 PM   #1074
TJ's Chevy
TJ's Chevy's Avatar
New parts in! Yeehaw!
Old 05-29-2015, 03:32 PM   #1075
Pappyx3!
Pappyx3!'s Avatar
Congrats! how about some pics of that first ride?
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400
1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver
John 3:16
Pappyx3! is offline
Closed Thread
