Old 05-28-2015, 02:34 AM   #451
T-P Auto
Re: The "Frankenstine" build;
Kodiaks;
Thanks for the reply;
It looks like I will get the legal paper work on Tue to get my project tagged n insured with a new title.
T-P Auto
T-P Auto is offline   Reply With Quote
Old 05-28-2015, 09:15 AM   #452
oldman3
oldman3's Avatar
Originally Posted by T-P Auto View Post
Kodiaks;
T-P Auto
That sounds great Tim...Jim
oldman3 is offline   Reply With Quote
Old 05-28-2015, 05:17 PM   #453
Advanced Design
Advanced Design's Avatar
Good work on the truck Tim! Mowers should sell really well this time of year. Happy selling!
Advanced Design is offline   Reply With Quote
Old 05-29-2015, 08:29 AM   #454
T-P Auto
Hello;
Well got the truck wired in,lites turn signals brakes just no charge system.
When I do hook up the Alt to charge it works but not able to shut if off till I disconnect the charge wire. ? ? ?
Useing a S10 wireing diagram. ??
Will reck the wireing again today,had to stop last evening as was getting upset with it.
I did get the cooling n ps fluid in n drove it around the block a couple of times.
The heater core did not leak so that was good, no ps leaks either, the radiator took like 3gal to fill up the system( bigger radiator then I thought).
T-P Auto
Old 05-29-2015, 12:55 PM   #455
oldman3
oldman3's Avatar
Tim, congrats on the drive around the block. I will see if I can find anything on the alt problem...Jim
Old 05-30-2015, 03:54 PM   #456
T-P Auto
Hello Everyone;
Well got the wiring done today.
Got a bad headlite switch(gets hot) more cking on that later.
Ck out the pic of the truck outside today !
Going to try to get the seat reinstalled,so able to drive it better.
Drove it around the block here a couple of times today.
May try to get the door panels installed also, even with out the windows in for now.
Just n update today(wrong date on pics)
T-P Auto
Old 05-30-2015, 03:56 PM   #457
T-P Auto
oldman 3;
Got the problem fixed with the Alt.
Did not have the wire in the right place to work.
OOPS ! !
T-P Auto
Old 05-30-2015, 03:59 PM   #458
T-P Auto
Hello;
Have not gotten the front dents out of the hood yet,plus still need to make a hood latch brace.
Hope to get on that later this week after the trip to inspect n tag the "Frankenstine" project.
T-P Auto
Old 05-30-2015, 04:23 PM   #459
Advanced Design
Truck looks good sitting out Tim! Glad you got the alternator wiring fixed.
Old 05-30-2015, 07:01 PM   #460
T-P Auto
AD;
That whole elect wiring took me like 3days to work out.
I did keep notes for the next time.
Going to take a brake tomorrow.
Just let my mind rest.
Got the DS seat installed for the trip to get inspected n taged.
T-P Auto
Old 05-30-2015, 07:03 PM   #461
T-P Auto
OOPS;
Here are the pic of the DS door n seat;
T-P Auto
Old 05-30-2015, 11:19 PM   #462
oldman3
oldman3's Avatar
Tim, glad the alt. was an easy fix. Good luck on the inspection and tag deal...Jim
Old 06-03-2015, 07:23 PM   #463
T-P Auto
Hello Everyone:
YAHOO
Got the truck inspected n taged.
Cost me 120.00
How I can drive it anytime I want to.
I need to ck on the exhaust system it is a lil loud.
Not sure that I tighten up the exhaust bolt to pipes ! ! !
Runs out good,drove it to the sheriff department for the inspection.
It is NOW a 1988/1950 chevy ;
T-P Auto
Old 06-03-2015, 07:28 PM   #464
Advanced Design
Congratulations Tim! Gee...hope the updates don't end now......
Old 06-03-2015, 10:13 PM   #465
flashed
Congrats on being legal .
flashed is offline   Reply With Quote
Old 06-04-2015, 08:10 AM   #466
T-P Auto
AD;
now comes all the lil small fine tuning stuff.
Will keep you all posted as I go.
Have to go help tear down n old shed for a few fays.
I do get all the lumber n tin from the building.
So i will be worth the time to do it.
Plus:
getting calls to work on some lawnmowers for friends.
T-P Auto
Old 06-04-2015, 12:35 PM   #467
oldman3
oldman3's Avatar
Tim, congrats on being legal with the truck. Be careful tearing down the building...Jim
Old 06-04-2015, 07:04 PM   #468
T-P Auto
oldman3;
flashed;
N
AD:
Thank You All;
I will be taking my time on the building.
T-P Auto
Tim;
Old 06-12-2015, 08:30 PM   #469
T-P Auto
Hello All;
Have just been taking a break n enjoying the truck.
Have a fuel problem to work out.
getting dirt in the carb so run it down to pull fuel tank.
While tank is down n out will replace the fuel sending unit out of the 78 chevy so then the gauge n sending unit are the same volt/amps?
Have had a lot of fun in the truck n really enjoying it.
T-P Auto
Old 06-13-2015, 09:07 AM   #470
oldman3
oldman3's Avatar
Tim, great that you are enjoying the truck...Jim
Old 06-13-2015, 12:58 PM   #471
Advanced Design
Good for you Tim! Always a fun time enjoying what you have built.
Good luck with the sending unit change.
Old 06-13-2015, 01:03 PM   #472
T-P Auto
Thanks;
oldman3;
I did run into a lil problem;
The fuel tank looks like it has some dirt in it;
There is not a problem as I have to pull the tank to replace the sending unit anyway.
That is what I have planned for today.
Got the tank out from under the 78 just a few moments ago.
NOW it is raining;
Willl work in the shop on the truck tank in abit.
Just hope that the sending unit is not to rusted up.
T-P Auto
Pic to follow in next post;
Old 06-13-2015, 04:23 PM   #473
T-P Auto
Hello Everyone;
Worked on the gas tank today.
got the old sending unit out of the 78 chevy. (pic)
For not having had gas in that for over 10yr the sending unit was really in good shape (pic)
Removed the 4x4 tank out of the truck n replaced the sending unit from the 78 into the 4x4 tank.
Had to cut off the end of the pick up tube to fit the 4x4 tank, just use a NEW elect fuel pump filter on the end of the pick up tube. (no pic)
Checked to make sure that the fuel was picking up fuel n it is n running.
Got the NEW tags on the rear (pic)
Added a NEW tag to the front all so (#3) (pic)
It have been raining here off n on all afternoon (love it)
T-P Auto
Tim;
Old 06-13-2015, 04:25 PM   #474
T-P Auto
still more pic;
Old 06-14-2015, 04:52 AM   #475
Kodiaks53
Looking good Tim, I know its fun to drive what you have worked on so hard. Congratulations! I just drove mine out of the shop yesterday after 25 years! Very good feeling.
Kodiak's 53S10 Build
Kodiaks53 is offline   Reply With Quote
