Old 02-10-2004, 07:49 PM   #1
jhow66
jhow66's Avatar
Fuel sender ohm range
What is the ohm range of a fuel sender for a 72 Cheyenne?
The one I took out read : E= 2 ohms, F= 48 ohms--the case was stamped 90 ohms.
Bought a new sender-E=1ohm, F=38ohms.
Gauge was going only a little past 1/4 when full--disconnect the sender wire it goes to full.
Tried the new sender on another gauge and it read the same as old gauge and old sender. (all of this was with sender out of tank)
Had it hooked up right and grounded good.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 02-10-2004, 07:53 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
I *think* it is 30-90 ohms. Someone please correct me if i'm wrong.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 02-10-2004, 08:06 PM   #3
cableguy0
it is supposed to be 0-90 ohms on a gm sending unit
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 02-10-2004, 09:34 PM   #4
JimKshortstep4x4
Talking
You still have a problem with your sender. Ohms should be 0 to 90 as cableguyo stated.
Jim
Old 02-10-2004, 11:14 PM   #5
Tim Christian
Tim Christian's Avatar
If the new one is not working correctly give me a yell.
Tim Christian is offline   Reply With Quote
Old 02-10-2004, 11:44 PM   #6
lukecp
lukecp's Avatar
Well guess i was wrong. Thanks for correcting me
