Old 05-28-2015, 06:13 PM   #1
lucusbumanlag
Starter issues
I have a 72 c10 with a 350/th350. When I start the truck it makes a horrible grinding sound. The truck starts right up within a second or two but it makes that grinding sound. What could it be? A bad solenoid? Completely bad starter? Or just might need a shim job? Just wondering what you guys think?
lucusbumanlag is offline   Reply With Quote
Old 05-28-2015, 07:12 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Starter issues
My first thought is shims. But if it worked before and doesn't now, then that doesn't seem too likely. If it were me and it's been a while since the replacement, I'd replace the starter.
Believe it or not, I had one experience where it was a bad starter AND battery. Seemed the battery wasn't providing enough juice and contributed to grinding. That was back in the day I thought a cheap battery works as well as an expensive one.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 05-28-2015, 07:39 PM   #3
franken
Re: Starter issues
Get under it, remove the cover and look when the gear engages.
Old 05-28-2015, 08:15 PM   #4
Custom/Ten
Custom/Ten's Avatar
Re: Starter issues
First thing I'd check for is loose starter bolts. If it's not that do what Franklin said.
Custom/Ten is offline   Reply With Quote
Old 05-28-2015, 08:36 PM   #5
Secret Squirrel
Secret Squirrel's Avatar
Re: Starter issues
When my starter went out it started with same symptoms
________________________
72 Olds Cutlass w/442 option
69 C-10 Short Bed Fleet
1960 Biscayne Wagon/El Camino
1995 YJ 4.0 SOA SYE on 35s
01 Excursion Limited 7.3 PSD
06 Suzuki DRZ 400S
Secret Squirrel is offline   Reply With Quote
Old 05-28-2015, 10:00 PM   #6
Wrenchbender Ret
Re: Starter issues
I used to get one like that occasionaly back when I had a shop. It usually caused by the gears not meshing deep enough. Replace the drive on the end of the starter & make sure the bushings are good. Take a large rough file & go across the mounting surface of the starter. The metal gets pulled up & lowers the starter away from the flywheel. That generally fixes the problem. If you go to far which never happened then you can use a shim. These starters are not hard to work on yourself.
Wrenchbender Ret is offline   Reply With Quote
Old 05-29-2015, 01:32 AM   #7
71CHEVYSHORTBED402
Re: Starter issues
Especially with butt connectors. I had mine in and out three times to get the height right. The last two times it took 10 minutes each tops, and if I can do it........Didn't think to use a file.
Tony
Old 05-29-2015, 01:45 AM   #8
lucusbumanlag
Re: Starter issues
Ok thanks for all the feedback you guys. I think I might just buy a completely new starter and start from there.
Old 05-29-2015, 07:23 AM   #9
MARKDTN
Re: Starter issues
If I did, I would buy a later gear-reduction type instead of the original. If you have an HEI or similar distributor that will be no problem. If you have an original style distributor, then you have to deal with the start circuit to the coil.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 05-29-2015, 12:23 PM   #10
71CHEVYSHORTBED402
Re: Starter issues
Pulling that cover to see what's going on is a good idea as well. Not sure why I didn't do that. What is there, two bolts?
Note: Get a good starter (not cheap) if it comes to that. Like I said, I installed it three times with the last replacement. Heck, it might have been four times (twice for adjustment). Somewhere in the middle I replaced the battery with a GOOD one as well. I'm no mechanic, but solid juice to the starter seemed to have had some impact on the gears. Less drag I guess.
Tony
Old 05-29-2015, 12:25 PM   #11
71CHEVYSHORTBED402
Re: Starter issues
In what way does gear-reduction reduce gears?
Tony
Old 05-29-2015, 12:47 PM   #12
trapdoor2
trapdoor2's Avatar
Re: Starter issues
While your under there checking on stuff, check all the electrical connections and wires...including grounds. Poor/reduced power delivery can cause weak/short gear engagement, etc.
Grinding noises = bad juju. Dey say, "Fix me now! If dey stop: de gods have judged your wallet be too full!"
===Marc
'55 Buick Roadmaster Riviera 76R
'69 Chevy C-10 CST/10 396 LWB, auto, air, PS (PB soon!)
trapdoor2 is offline   Reply With Quote
